idle jumps BAD!!!!
Old May 17, 2004 | 09:39 PM
90240sx's Avatar
idle jumps BAD!!!!
hi my 90 240 sx is running really bad the car dont want to idle or run if you floor the gas it jumps back and forth between 2 and 2 1/2 just replace the tps and o2 sensor anything else that could cuse this please help
Old May 17, 2004 | 10:40 PM
LTSCUDRFT's Avatar
EGR valve maybe.
Old May 18, 2004 | 08:46 AM
90240sx's Avatar
thanks is there a way to tests it before i buy one
Old May 18, 2004 | 02:00 PM
90240sx's Avatar
just replaced the egr valve better but still not good sounds like a little bit of a backfire but im not for sure
Old May 19, 2004 | 10:33 PM
LTSCUDRFT's Avatar
it could be your egr control solenoid valve i had to replace mine i payed $17.50 CDN from a junk yard.
check it out.
Old May 19, 2004 | 10:38 PM
LTSCUDRFT's Avatar
EGR valve
here is a pic so you know where it's located, it's on the upper left.
ToRu
May 9, 2006 10:48 PM
s13driftslut69
Jun 17, 2005 02:35 AM
M374llic4
Mar 26, 2005 08:10 PM
irax
May 4, 2004 08:55 PM
