idle problem, on a 240? no wayyy!!!... i wish..
Old Feb 10, 2009 | 12:26 AM
fadedsilvia's Avatar
soooo this is boggling me
when im pulling up to a stop (on or off the brake) and im not in gear, the idle goes down to a couple hundred RPM, an stays there till i come to a complete stop, the hunts for a second or 2, then settles back to normal
ne ideas?
i have seen alot of idle problems, but not one like tihs before.
i havnt started digging into the engine yet either but im lookin for ne sort of info that i can find before i do, nething helps!
Old Feb 10, 2009 | 11:37 AM
a drop in idle speed the way you describe is indicative of a faulty aac valve. it's part of the iacv. you'll need an ohm meter to test it. iirc you should have 10 ohms or there about.
Old Feb 11, 2009 | 12:16 AM
awsome! ill try that out
i was gonna go through an clean out the PCV, and MAF, an throttle body and a couple other things as well jus to make sure, the idle adjustment should be fine so i wont touch that, an the timing i have advanced 5 degrees an i no the ignition system is all good, so that wont be touched either
but thanks bro
there anything i can do with the TPS? any sort of adjustments or anything?
Last edited by fadedsilvia; Feb 11, 2009 at 12:17 AM. Reason: im probably half retarded
Old Feb 11, 2009 | 11:11 AM
all the things you mentioned are probable possibilities but from your description the i'd say that the aac is more likely. since you have a 95 it might be obd II which would make it easier to diagnosed. regardless if it's obd I or II you should check for codes. not all the things mentioned will give you a code though.
s14.5boy
Mar 4, 2004 11:38 PM
streetrays
Dec 26, 2003 02:01 PM
leiferik1
Feb 15, 2003 07:39 AM
Ben
Feb 10, 2002 09:27 AM
