Itb.
Old Jun 7, 2010 | 06:22 PM
lifted&lowered's Avatar
Itb.
Well I was doing some research on ITB for my 240 and I came across a HOW TO thread on here about them and I have a few questions that I am not really understanding. First off I am about to order the throttle bodies, they are coming off an 03-06 gsxr1000. After I get them I am going to plug the injector holes on them. Good so far? Now I read I had to put a TPS sensor in the mix somewhere? Where would be the best? And to tune it you can use a SAFC. Well I have an SAFC2 controller. Will this accomplish it? Thanks for the info,any other help will be useful!
Old Jun 7, 2010 | 07:36 PM
240-kid's Avatar
You have a lot more to read and look into because unless your making a Manifold you'll need to run a MAP based ECU system cause you can't use a MAF w/ a Plenum.
Old Jun 7, 2010 | 07:45 PM
How do I run a MAP based ecu? Cause since I am removing my MAF sensor I must switch to MAP. I plan to take an old manifold I have and cut in half to mount the throttle bodies.
Old Jun 7, 2010 | 11:42 PM
map based systems correlate with stand alone ecu's
Old Jun 9, 2010 | 05:57 AM
sav180's Avatar
i know xcessive makes a intake mani wit itb's into a plenum so u can still use maf
Old Jun 9, 2010 | 10:25 AM
I was looking into it even more If I made my own Plenum is there a demensions I have to follow? Cause while I'm in school I am going to machine my own plenum.
Old Jun 9, 2010 | 11:58 AM
240-kid's Avatar
There's a few books about designing your own Manifold, there's also some good articles from popular mags Like Hot Rod and even Superstreet. Might want to look into that...
Old Jun 9, 2010 | 10:52 PM
I will do that. Thanks!
With ITB and a plenum would I gain as much as I would with no plenum and a standalone?
Old Jun 10, 2010 | 06:23 PM
in our world its more of a cool factor it seems than performance. I have no first hand expereince with them so I cant give information really bro.
deviousKA
Jan 14, 2008 10:52 PM
clubredsilvia
Aug 13, 2007 07:33 PM
Killer240SX
Apr 28, 2006 01:14 PM
CowboyTurbo
Oct 13, 2005 03:28 AM
sage
Nov 8, 2004 10:43 PM
