KA24DE And KA24E
KA24DE And KA24E
Will both trans fit the same? Im looking to do my swap and like i found a parts car which is an 89 and mines a 91. Could It work? Please let me know. I know this is a noob question probably to most of you guys. But this is how i learn. :P
search bro... every question you got has been discussed.
https://www.s-chassis.com/forums/how-tos-installations-48/auto-manual-writeup-5-speed-swap-33633/
https://www.s-chassis.com/forums/showthread.php?t=33633
.....its the same process.
the only difference is under the fuse box in the engine bay of the S13, you are going to wire the inhibitor switch together.
and as far as the tranny you can use ANY tranny on a 89-early 95 KA
however as stated, you can,t use a 89-early 95 KA trans on mid-late 95-98 KA's due to the Crank Angle Sensor (CAS)
Right now I am using a rebuilt KA24E tranny for my KA24de, I am however using a KA24de auto ecu.
Only OBD2's use the sensor to the flywheel and it isnt located on the tranny.
KA24e transmissions only use a 4th gear speed sensor, that regulates fuel and speed.
KA24de transmissions use a 4th and 5th gear speed sensor, that regulates fuel and speed.
sohc_240sx
Nov 7, 2006 09:13 PM
