KA24DE Swap
KA24DE Swap
Alright guys -
Here it is. I have a 1989 240sx with a KA24E. I have just recently found a 1993 240sx parts car with a KA24DE. I have always wanted the DE because i heard of its potential. The guy only wants $800 for it because it has been wrecked in the rear. First question is do you think its worth it if the motor is in great condition? Second question is just how difficult is it to do the DE swap. Thanks
sounds like a good deal as long as the motor is really good. as for the swap i believe there are some wiring changes that need to be made, but other than that its pretty standard....do some searching to find out about the actual swap
Re: KA24DE Swap
Originally posted by 240Boogyman
Alright guys -
Alright guys -
if you decide to pick up the whole car, get these:
engine
transmission (that way you don't have to unbolt it from the engine)
engine harness
body harness (under dash harness. if you don't want to get this, you can also use the one on your car right now, but you're gonna have to cut and rewire/color match with the engine harness. Note: there will be wires left over if you do this.)
power steering reservoir and the hoses/lines
whole intake (tube to the air box)
coil
tach (if you want one that works)
engine-side brake booster vacuum hose
throttle cable
cruise control cable (if you have it)
power wash/clean your engine bay and swap the engine to its new home.
good luck with it.
engine
engine harness
coil
throttle cable
good luck with it.
I appreciate all the input guys. I am suppose to go check out the car this week. I am also suppose to go test drive a 1990 Nissan 300zx tomorrow. The guy only wants 2K for it. Anyways thanks again.
1991se240sx
Jul 31, 2009 09:58 PM
Indolent
Sep 3, 2006 02:51 PM
