Ka24e Ecu On A Dohc Engine?
Old Sep 26, 2005 | 10:02 AM
TorqueFreak240's Avatar
I am doing a engine swap and i want to get the car running asap. I have a 95 dohc engine going in and was wondering if for now the sohc engine ecu would work with a dohc engine? it plugs in ok but i'm not sure if it would start and run with it in any body know? this is just a temp thing like maybe a week or 2!
Old Sep 26, 2005 | 04:02 PM
Im not sure if it would work even if it plugs okay. Since the KA24E ECU is programmed to run only a single cam, a certain fuel amount, SOHC timing, etc.
But I might be wrong...
Old Sep 28, 2005 | 03:34 AM
wikd240's Avatar
i dont think it will work at all... the pin outs are in different places on the ecu... the fuel and timing maps are totally different and if i remember right even the power is from a different pin... you could try it at the risk of smoking the ecu... but i would get the ecu you need befor i try running the car... after all you are doing the swap why skip a step and possibly do damage to the motor or the car???
Old Sep 28, 2005 | 05:02 AM
i knew the fuel would be different but i just wasn't sure i found a new ka24de ecu anyways but thanks i was wondering if anyone was going to reply thanks.
Old Oct 1, 2005 | 03:04 PM
BigVinnie's Avatar
Dude SOHC ecu's can work on dohc's. You just wont have a knock sensor thats all. Leave your sohc harness and ecu, and just install the dohc.
I think sohc ecu's are cool anyways, they are super easy to chip out.
Old Oct 1, 2005 | 03:09 PM
Chiefgmsr's Avatar
A friend of mine actually felt his dohc was faster w/ his sohc ecu. But then he changed to the dohc ecu and it didnt feel as fast.
Old Oct 6, 2005 | 10:11 PM
so i can use my sohc ecu and harness?
Old Oct 6, 2005 | 11:03 PM
silver240esex's Avatar
You should be able to. I have an 89 240sx hatch with a 95 ka24de and a sohc ecu. It works!
Old Oct 7, 2005 | 01:25 AM
wow thanks thats great thats the same setup im running a 95 engine in my 89 lol is pretty peppy with that engine silver240esex?
Old Oct 8, 2005 | 03:22 AM
It does run nice. I have a dohc harness on the way. I have a Dohc ecu and I can't wait to try it on. The DOHC ecu doesn't work with the SOHC harness. At least on mine it doesn't...LOL!!!
Old Oct 8, 2005 | 12:30 PM
thats cool i have a turbo setup im getting ready to install all i need is the manifold to put it on then i should be ready for a little boost i cant wait to let her rip.
naptime
Oct 26, 2006 06:14 AM
silver240esex
Dec 10, 2005 12:48 PM
globalsilence
Dec 7, 2005 12:41 AM
pumaking
Nov 6, 2005 09:03 AM
konseiEva
Dec 13, 2002 03:17 PM
