KA24E SOHC Fuel Filter
I just did this and replaced with a 300zxtt filter. It is in the engine bay behind the battery. Word to the wise though, pull your fuse (by the battery) and loosen your gas cap, then crank your car a few times, and when you remove it make sure to have a few towels. (I did all this and still ended up with a face full of gas, maybe should have cranked a few more times, or removed bottom hose first).
You can actually pull the fuel pump fuse, then start the car and let it run itself out of gas - it will only take a couple of seconds for it to die - to depressurize the fuel line.
The filter is actually mounted to the passenger side strut tower. It's hard to miss.
Limited Slippin
Mar 17, 2016 09:27 AM
BILLYhoang
Mar 17, 2008 08:51 AM
240sx, change, clean, filter, fuel, install, it, ka24e, ka24efilter, ka24efuelfilter, location, removal, replace, replacement, replacing
