ka24e vs ka24de
Old Oct 9, 2002 | 09:28 PM
StanBo's Avatar
200 rwhp is much more when taken into account at the flywheel. I don't know what the driveline loss calculation is but for ****s and giggles lets say it is 20%.
So you would be talking about 240 crank HP. That is a big jump from the stock 140 HP.
100 horses are not made without loosing things like torque. That would make it a ***** to start and stop. Traffic would be a nightmare.
I think Idle would also go in the garbage. I have driven in cars with aggressive cams. My uncle's Z car drove like a paint shaker until he got on it heavy. His idle was rough. This is not something you want for a daily driver.
I would also think that the HP would be made at a high rpm. Something like the Vtec system where it is not used much unless the car is revved hard.
Fuel might be a problem. I don't think you can make that much power on 93 pump gas. You would most likely have to run a higher octane.
Maintenance would be too high to drive it all the time. I have co-workers who made mistakes of following domestic mag build issues. They built cars that had high HP but had to have the oil changed at a higher rate. The plugs fouled quicker. On and on.
There must be some other reasons.
Old Oct 9, 2002 | 09:42 PM
xriz's Avatar
so i guess a FI setup is the more streetable reliable and cheaper route to go...
Old Oct 10, 2002 | 03:18 AM
StanBo's Avatar
I would think so. That is the route most guys go. It doesn't mean that All Motor is crap. All Motor guys get a lot of respect in my book. But I would go for the boost. Exhaust is already there, might as well us it for good.
Old Oct 10, 2002 | 07:59 PM
xriz's Avatar
is there a streetable cam for the ka24e ?
Old Oct 11, 2002 | 05:43 PM
TonysS13's Avatar
wow there is some sohc respect in here . i truly am amazed by that
as most of you know i have a sohc ka and im turboing it next spring,i was gonna do it this month but my ecu is taking forever to come back from jwt (3 months now grrrr!!!) and i was gonna run it at 6psi on stock internals but i changed my mind and im gonna go get some pistons and rods so i can run 12 psi safely
so ima wait till next spring
Old Oct 11, 2002 | 10:09 PM
StanBo's Avatar
Check out the guys at PDM Racing. Click Here
Old Oct 12, 2002 | 06:07 AM
Import Fanatix's Avatar
FYI, we have gone over the "15 post limit" on this thread as previously was a problem. Hope its all good now, and this thread was not deleted as originally thought.
Old Oct 12, 2002 | 10:44 AM
xriz's Avatar
does nissan motorsports make a streetable cam ?
Old Oct 12, 2002 | 11:08 AM
95exlude's Avatar
I believe that most 240s lose 17% through driveline.
Also, I have a n/a civic that makes 204hp on pump gas.... But then again, honda excels on na.
Old Oct 12, 2002 | 12:36 PM
StanBo's Avatar
What is it running a b18?
What octane?
Does it have any maintanence problems?
Old Oct 12, 2002 | 09:21 PM
  #26
rudeboy's Avatar
my SOHC pulls hard liek rotwiler
somethin serious
Old Oct 13, 2002 | 05:13 AM
  #27
TonysS13's Avatar
better belive it !![
Old Oct 29, 2002 | 02:05 PM
  #28
AceInHole's Avatar
FWIW, SOHC KA's are capable of at least a good 240 crank HP while still maintaining streetability. Just look at the 510's that do it with a carbed setup. Loosing streetability comes towards the 300hp area from what I've heard and seen.
Old Oct 31, 2002 | 07:26 AM
  #29
nismo180sx's Avatar
I d ratehr have the DE instead of the E more HP and DE are really good for turboing as well but I d still rather have a ca18det
Old Oct 31, 2002 | 08:40 AM
  #30
AceInHole's Avatar
A better reason might be that DE's are newer.
Otherwise, you'd pretty much have to prove that the DOHC head flows better, and makes up for a heavier valvetrain. Some of the SOHC setups, both NA and turbo, are actually pretty nasty (as in the NA setups usually blow away any DOHC comparison, and the turbo setups compete with some of the best KAT's out there).
