kade pistons swap
Old Apr 14, 2008 | 07:48 PM
sav180's Avatar
kade pistons swap
what the difference bewteen 89/90 e pistons ??are 248x2 safe cam setup using these pistons??and can i use de rings on e pistons??
Old Apr 16, 2008 | 10:05 AM
Comp ratio is different. Yes they will work with dual248s. Im not sure about the rings tho. thatll be self explanatory tho when you get them side to side. .
This isnt a bolt on project tho. Invloves tuning.
BigVinnie should chime in, and explain more in detail.
Old Apr 17, 2008 | 03:40 PM
sav180's Avatar
anyone?
Old Apr 18, 2008 | 11:54 PM
240-kid's Avatar
89 = 9.1 C/R 90 = 8.6 C/R
9.1 C/R KAE Pistons on the DE will give you a Final 11.6 C/R.
Doing some Research It seems that The Valve Reliefs Do Not Align so Using Aftermarket Cams w/ SOHC Pistons should not be done
Old Apr 22, 2008 | 11:42 AM
sav180's Avatar
yo has anyone thought of using after market e pistons like from cp ??will it bump the c/r up jus like the stock ones?
Old Apr 22, 2008 | 07:24 PM
240-kid's Avatar
well I mean if the C/R is different, the final in the DE will also, ie 10.0:1 C/R SOHC will be like 12.5:1 in an DE. Highest I've seen for an DE is 11.0:1
Old Apr 23, 2008 | 06:02 PM
sav180's Avatar
me to thats je pistons.. i was just askin cuz i dont wanna bore out the motor..cp sohc were 9:0:1 so that sounded perfect
Old May 1, 2008 | 08:26 PM
sav180's Avatar
what u guys think
Old May 1, 2008 | 09:59 PM
240-kid's Avatar
I dont quite understand what you said in the last part of your last post????
Old May 2, 2008 | 06:36 PM
BigVinnie's Avatar
You can't use high lift and duration cams with the 89 pistons. You will be limited to 240/248 cams and be making minimum clearance between the valve and piston. I would say get the 90pistons and be happy with a 10.7:1CR.
Either that or have a head shop shrink the quench chamber for you.
If your not going to ecu tune you will at least need an SAFC
Old May 4, 2008 | 04:42 PM
sav180's Avatar
sweet...tankx vin
Old May 5, 2008 | 12:46 AM
240-kid's Avatar
Hey vin, w/ the 90 Pistons, do you know how much clearance there is?
would a 248/248 Exh cam combo work?
What about the Nismo 248/256 10.7mm lift?
Old May 6, 2008 | 07:40 PM
sav180's Avatar
if that does clear then bc 264/264 Duration
9.52mm/9.52mm Lift should no problem at all or no????drop some knowledge upon us vin
Old May 6, 2008 | 07:43 PM
sav180's Avatar
im tryin 2 avoid havin to bore my block out to save time and money wit this cam selection...what are the "++'s" to havin your block bored out?
Old May 11, 2008 | 05:07 AM
240-kid's Avatar
Well not exactly, thought it may have less lift, the valve will be open much longer thus the valve being more open longer
