Keeping the KA Smooth
Old Jun 12, 2005 | 09:03 AM
BigVinnie's Avatar
Originally posted by wikd240
bars stop leak... they make it for the radiator... there is some in a grey/sliver bottle and some in a clear bottle... get the stuff in the clear bottle with the pelets in it... one bottle will do you just fine... there is also some stuff called liquid glass... it is clear with a copper color liquid in the bottem of the bottle... it is good stuff too but you have to completely flush all antifreeze out of the motor for it to work right...
Sorry wikd I will have to disagree with you there. I still respect your input though. Bars stop leak is bad very bad! Those aluminum pellets actually do more harm than good, they actually plug up the heater core, and it is a motherfuc$er replacing the heater core.
Use regular house hold pepper a couple table spoons, it will work it's way to the leak and seal it temporarily until you can fix the problem. Pepper is easy to flush out also that bars stop leak doesn't flush and reduces the size of coolant passages within the block, can actually raise the temprature of the engine if you use to much of it.....
Just my 2cen't from a couple years of driften hard.......
Old Jun 13, 2005 | 03:31 AM
wikd240's Avatar
i agree with you on the bars... it is a cheap alternitive for people who cant afford other ways of fixing... i would use liquid glass if i had the choice... the copper in it will only bond to copper... radiator welds and heater core... and in most cases the lead in the head gaskets... it wont bond to any of the rubber lines or the steel lines in the car...
ronnycage
Mar 21, 2007 12:58 AM
n3wbie
Aug 28, 2003 03:17 PM
