leaky injectors
Old Nov 27, 2002 | 08:08 PM
kellyanne's Avatar
Question leaky injectors
I have a 1989 nissan 240sx 2.4L. I also have leaky injectors, I need some advice on how to fix this problem please someone help me!!!!!!!!!!!!!!!
Old Nov 27, 2002 | 09:24 PM
spitz7985's Avatar
get new injectors
Old Dec 1, 2002 | 04:26 PM
lenny22's Avatar
I worked on my girlfreinds car today with the same issue (also a 89 2.4). We thought we could get out cheap with just the O ring kits for each injector to solve the problem.
After replacing each O ring and (2) rubber gormets per injector the leak was a little less (still leaks) but now have other issues.
Car running a little rough at idle but try to put into gear and it shakes terrible and wants to die.
Any ideas?
Old Dec 1, 2002 | 05:34 PM
PSM's Avatar
PSM
*****istrator
Check those o-rings. Make sure you get o-rings for fuel injectors, not just any o-ring from home depot, track auto etc. You may also need to lube the bottom o-ring to get the injectors back in the manifold.
Old Dec 1, 2002 | 07:01 PM
kellyanne's Avatar
dont die 240
well make sure you removed the sensor for the feul pump, and put it back in when u were finished. Also did u have to remove the bpt valve? Did u use 3 o rings on each injector?
kellyanne24@lycos.com
msnm
Old Dec 2, 2002 | 06:04 AM
lenny22's Avatar
We bought the kits from Napa. It only has one O ring that seats inside the fuel rail, one gromet that seats against the fuel rail, and another gromet that seats to the manifold for each injector when you tighten the fuel rail bolts.
I'm not sure what the fuel pump sensor is or where it is located.
The car ran fine ( just had a leaky injector) before the swap and now it falls on its face when trying to put into gear.
This was not rocket science- it was easy fix. Could it be another issue in the fuel delivery system now that the leaky injectors are fixed
Old Dec 13, 2002 | 01:55 PM
lenny22's Avatar
We have diagonsed the problem. It is with the fuel injector connectors.
Nissan wants like $300 bucks to replace the connectors.
Does anyone have a set or can these be purchased aftermarket?
Old Dec 13, 2002 | 01:59 PM
rudeboy's Avatar
YOU SHOULD JUST GO GET A NEW SET.. WHY PAY FOR SOME ONE ELSES JUNK?
unless it's cool junk
s240r
Jun 8, 2003 07:09 PM
corey2k
Apr 22, 2003 12:30 PM
kellyanne
Nov 29, 2002 06:16 AM
kellyanne
Nov 28, 2002 09:04 AM
Import Fanatix
Jul 27, 2002 05:41 AM
