leaky trunk
Old Jun 2, 2003 | 12:23 PM
s240r's Avatar
leaky trunk
Hey, whenever it rains and i have stuff in my trunk it gets wet, underneath the rear mat is soaking, i put in new tail lights and didnt re-seal them with that black junk that was origanally on them. Do you think the wet is coming in through the lights, or the hatch seal? thanks dave
Old Jun 2, 2003 | 02:07 PM
Krise013's Avatar
i had a similar problem with mine. if you have a stock spoiler on it then what happened to mine was that it rusted under the spoiler where the bolts are and leaked in through the rust. if this is the case then some good old JB Weld should do the trick.
Old Jun 2, 2003 | 07:12 PM
I'm with Stupid's Avatar
I'd say it's your lights. You should seal them.
Old Jun 3, 2003 | 09:11 AM
S13Nissan240SX's Avatar
Whether it's the lights or not, you should go in there and seal those off. If you don't have the black stuff then you might be able to just use some silicone.
Best wishes,
Matt
Old Jun 3, 2003 | 06:46 PM
Amolao's Avatar
Thumbs up You use the real stuff.....
Hi, you need to reseal those lights with the right material, silicone wont do.... I had the same problem and the only thing that stop the leak was to take the lights out, clean the contact area (around light and cavity) and use brand new material, you can buy at Auto Zone or any auto parts store...I think is called Butyl.....??? Comes in a roll. Apply it and heat with blower then mount the lights and Wollaaa!!! NO leaks my friend.....
Stay dry!!!
Old Jun 4, 2003 | 12:45 PM
Re: You use the real stuff.....
I stand corrected. Sorry about that.
---Matt
Old Jun 5, 2003 | 09:26 AM
cyclotron_Burst's Avatar
I have the same leaky trunk problem...and found that it was the stupid mounts on the stock spoiler. One of the bolts had fallen off and was letting water in the hole. I just used a piece of electrical tape on the inside for now untill I replace the spoiler
Old Jun 7, 2003 | 09:09 PM
fastback's Avatar
so its the damn spoiler.... i finally know, thanks. so if i jam some jb weld around it it should seal?? any other/better ways to seal it??
Old Jun 7, 2003 | 10:53 PM
I wouldnt exactally use jb weld unless you plan on permantly sealing that hole....I would hit up the local auto parts store and see if they have any of that gummy black sealant or something along those lines. so if you do ever decide to replace your spoiler you can..But I have noticed that the spoiler on the S13 was not exactally designed to really last....but crap happens
Old Jun 8, 2003 | 07:09 PM
fastback's Avatar
o, i took my spoiler off today, and lets just say, it died long ago, what used to be a stiff, metal lined spoiler, can now bend all over. its completly rused out. so of course, i put it right back on, haha. but first, i pulled out the white plugs, and sealed them with some 3M emblem adhesive, just put a big patch over the hole, hopefully it wont leak anymore.....
battosaii930
Jan 16, 2007 09:12 PM
kellyanne
Dec 13, 2002 01:59 PM
kellyanne
Nov 29, 2002 06:16 AM
kellyanne
Nov 28, 2002 09:04 AM
Import Fanatix
Jul 27, 2002 05:41 AM
