let's talk throttle bodys : )
Old Apr 25, 2005 | 05:52 AM
ProjectMy240's Avatar
on KA24DE's every year.. are the throttle bodys all the same size? I was wonder if i like a 95-97 would be bigger that I can maybe get and put on my 92 ka24de for a little bit more hp?
Old Apr 25, 2005 | 08:49 AM
thekage's Avatar
I compared the one off of my 89 e to my 96 de.. they look the same.. I know the de is 60mm.
Old Apr 25, 2005 | 10:51 AM
aww that stinks I was hopein like a 95-97 they would be bigger. guess not : (
Old Apr 26, 2005 | 10:57 PM
BigVinnie's Avatar
The reason why they are small is for torque..
Have you ever looked at the size of a stock OEM ford mustang 5.0 TB it is pretty small for a V-8, but it was made like that for torque.
If you want to shift the power band for high HP instead of torque get a larger TB with an atomizing TB spacer........
Old Apr 27, 2005 | 12:06 PM
Mine was sticking so i cleaned it. Works good now.
Old Apr 28, 2005 | 01:34 PM
ryoisaguri's Avatar
but then you defeat the purpose of our torquey KA's =D
Old May 1, 2005 | 09:59 AM
BigVinnie's Avatar
The perfect race engine should have an equal ratio of HP/torque.
If you have more torque than HP all you are doing is slowing down the full potential of the engine. Torque is nothing more than a byproduct of HP. Torque is great for keeping constant momentum, but HP is what you need to accelerate.
If the KA engine stock already produces more torque than HP, all you are doing is slowing down the potential to accelerate faster.
If you enlarge the TB you are freeing up HP and shifting the power band. The KA already produces a SHIAT load of torque through bore and stroke, might as well free up some degredation and get some donkey's added to that torque value......
Old May 5, 2005 | 04:30 PM
drew935's Avatar
Tb sizes
S13 SR20DET - 60mm
S14/5 SR20DET - 50mm
S14/5 SR20DE - 60mm
KA24DE - 60mm
Old May 5, 2005 | 08:39 PM
BigVinnie's Avatar
If the average 60mm comes on a 2.0 litre, a 2.4 KA should use atleast 70mm.
Honda H22 even have large 70mm throttle bodies........
Old May 5, 2005 | 08:57 PM
zeroGripS13's Avatar
vin.. i was always told that hp was a by-product of torque..can you clearify this...
Old May 5, 2005 | 09:34 PM
BigVinnie's Avatar
Other way around. Torque is the amount of impacted force delivered in 1 single stroke "or rotational mass", mostly in displacement. Larger masses can create more power. A 2.4 litre piston for example will drive more mass, compression and power than a 2.0 litre piston. HP is what allows 1 single stroke or rotation to spin faster. You basically can't have one without the other........
Take diesel engines for example low HP and a crap load of torque. For example the Datsun sd22 diesel has something like 60HP and 180ft/lbs of torque. The torque allows it to pull weight, but the damn thing wont go any faster than 80MPH, and is as slow as a snail......
If you make a unleaded octane vehicle anemic "smaller TB'S and ports" than having an even distribution of flow to displacement you are creating byproducts that prevent high HP numbers which is "torque". Torque doesn't make you fast in the 1/4 mile HP does, Honda has been proving that for years.........
But when you are dealing with heavier vehicles you will need torque to drive that heavy chassis to allow HP to accelerate, hense needing both "equal ratio of HP/torque" to achieve the perfect race engine......
Old May 5, 2005 | 11:10 PM
JDMxDrift's Avatar
Not to argue with you vinnie, but i was also informed that HP was a byproduct of torque. Torque is your initial power, correct? Horsepower is torque over time.
Old May 5, 2005 | 11:54 PM
BigVinnie's Avatar
If you look at statistics on vehicles with 1/4 mile times. High HP engines are the best achievers.
If you have an article based on FACTS that HP is a byproduct, I would like to read it.
Everything a have read states that HP is your common denominator...........
I've read books on the combustion engine's and no where does it state that HP is a byproduct...........
Degredated power loss produces torque, look at the differences between
stock headers vs. performance headers........
Stock pulley VS. the aluminum pulley......
stock flywheel vs. alyuminum flywheel.........
the power band changes where torque drops in small numbers, while HP raises in larger numbers, you really should study dyno charts more often.
If you like torque that much keep the inevitable stock trim KA SLOW..........
Old May 6, 2005 | 12:22 AM
JDMxDrift's Avatar
Again Vinnie, we're not trying to **** you off. Just trying to understand....
Old May 6, 2005 | 01:42 AM
BigVinnie's Avatar
Who is we? Am I getting ganged up in here or somethin??????
Advertisers, salesmen, of performance products specify Horse Power, "not torque", or maybe the "and torque"
What word comes after "horse"?
DUHHHH......... POWER!!!!!!!!!
When you take a shiat, are you creating POWER??????
When you take a crap you are making a byproduct, not power...
You use torque to push a "huge" terd out your ***.......
Was that disturbing analogy easy to understand!!!!!!!!!!!
