Motor mounts
Old Oct 27, 2004 | 04:00 PM
devnull's Avatar
Motor mounts
Does Place Racing make motor mounts for 240sx? Aside from OE and Nismo, what options are there for motor mounts and transmission mounts for our cars?
Old Oct 27, 2004 | 07:21 PM
Moved to N/A...
Only ones I know of are OEM and Nismo motor mounts, unless of course you are swapping engine then there will be a couple others. Or you can get custom mounts
Whats place racing...
Old Oct 27, 2004 | 07:29 PM
Project Cheap13's Avatar
Solid mounts..$6
Old Oct 27, 2004 | 09:10 PM
NismoKa's Avatar
Yeah
I would agree, solid motor mounts can be made easily from scrap metal. You just have to find some welding equipment, a tape measure and a grinder and you have yer self some sturdy *** mounts. Future project for me.
Old Oct 28, 2004 | 02:18 AM
devnull's Avatar
Place Racing makes good front and rear engine mounts for Altimas as well as other stuff.
http://www.placeracing.com/
Unfortunately their website is "under construction" and only tells you how to order a catalog.
Old Oct 28, 2004 | 05:28 AM
Hahah Place racing website has been "under construction" since 1998
Does Tanabe make replacement mounts? Or is that just tranny mount?
Old Oct 28, 2004 | 07:23 AM
The soild mounts in a 240sx are no laughing matter. They are annoying as hell, but if you dont mind eveything rattling. Then you wont have a problem.
I used round bar stock. Cut to legenth & drilled a hole through the center. Total time to make...15 minutes
Mine are 6160 Billet aluminum.
Old Nov 13, 2004 | 09:06 PM
barrigaS14's Avatar
there are a few places that make soild motor mounts. the Sr ones work for the Ka's. soild ones are very very very hard and cause everything not welded to the frame to vibrate. if this is a daily driver then get the Nismo ones.
Old Apr 15, 2005 | 04:05 PM
ca177or4's Avatar
thx...i was thinkin of gettin solids but i was thinkin of the vibrations. how are the nismo mounts anyways? are they alot better than the stocks? well im sure they are but how much more?
ilovesilvia
May 2, 2005 01:23 PM
sr20det power
Dec 14, 2004 05:46 PM
sqrlnts
Feb 4, 2004 03:49 PM
brodie
Nov 19, 2003 09:01 PM
Import Fanatix
Nov 25, 2002 11:34 AM
