my cams, your cams, clear up the cams
Old Apr 11, 2005 | 09:09 PM
smurphs_s13's Avatar
Angry my cams, your cams, clear up the cams
Otay so.. Will someone please clear up the cam issue ARE THE ANY FACTORE KA CAMS (or other nissan motor cams) THAT CAN BE PUT IN A 240sx AND ADD POWER OR TORQUE?? i like were bigvinnie is commin from he knows his ****. and sounds likes he loves the old school motors like myself.. my head is apart (blew head gasket) getting P&P and 3 angle valve job while the head is off and apart i want someone to explain this cam thing up if i can get a tad extra somthing (oomph) cheap ill do it.. ill look up the specs tommarow at work but want to know if anyone has ever done these so called "cam swaps"?? anyone done them?? i hear so many people saying do these do that use these cams.. but I have never actually heard of anyone doing them someone help me out a little??
Old Apr 12, 2005 | 03:35 AM
wikd240's Avatar
most of the cams for our cars are actually factory cams that have been welded and then reground... so to answer your question like that then yes there are... but to answer the question about cams... from what i know all of the cams from 91 to 93 are all 240/248 and the 95 ad up cams are 232/232... if you have a 93 you already have the cams...
Old Apr 12, 2005 | 05:28 AM
thekage's Avatar
Thats right Wikd.
IF you are looking for something cheap while its apart for cams.. not much you can do.
Regrind or JWTs.. either way its a pretty penny.
ps.. oh I forgot about PDM cams as well now..
Old Apr 12, 2005 | 06:00 PM
nissandrift's Avatar
you can use 2 S13 exhaust cams for so youll have 248/248 but when you put the S13 exhaust cam on the intake I beleive it has to be rotated 4 teeth.
Old Apr 13, 2005 | 03:40 AM
wikd240's Avatar
or get a set of adjustable cam gears and it is all good... yes you can add the exhaust cam on the intake side... it is good for a little more power and screams with a little timing work...
Old Apr 13, 2005 | 02:16 PM
drew935's Avatar
this would be the route I would if I was in your position for a lil extra power with only a lil extra money.
Old Apr 13, 2005 | 06:53 PM
BigVinnie's Avatar
Actually I just found out about a month ago you can retro fit CA cams to the ka.
Machine work will need to be done so that the KA timing gear sprockets can mount to the the cam of the CA.
There are an abundant of cam specs from japan that were meant for the CA that can be used for regrind onto the KA cams also.
You can also use cams from the KA trucks, the KA trucks were sold all over internationally.
I also believe that you can take cam specs from the old school FJ20 which I believe was also a bucket style hydraulic assembly valve train.
Old Apr 15, 2005 | 06:24 PM
Arnt the cam specs for the trucks the same as the 240? I have spare 240 motor.. so i can yank an exhaust cam but is the timming mark the same or wha?? I can get ca cams... probably local junk yard.. do machine shops to cam grinding?
Old Apr 15, 2005 | 06:37 PM
BigVinnie's Avatar
I ment to go look at performance cams for the KA trucks, there are an abundance of KA trucks sold internationally.... There are companys in other country's with different performance specs that may serve your needs..........
Old Apr 16, 2005 | 01:22 PM
wikd240's Avatar
the timing marks will not be lined up right... you have to rotate the cam to get it in the right position... you just have to be careful to make sure that it is in the right place... jim wolf technologies gives a picture of what the cams should look like when they are sitting in the head... pay no mind to where the pins are but look closly at the cam lobe location... it will be inbetween 10 and 11 position on a clock...
Old Apr 16, 2005 | 05:58 PM
BigVinnie's Avatar
So BTDC is different on KA trucks????????
Old Apr 17, 2005 | 07:53 AM
wikd240's Avatar
if they do the dual exhaust cam set up... the exhaust cam being used for the intake will have to be rotated 4 teeth to get it in the right position... meaning the timing mark on the gear will be 4 teeth towards the intake than the silver link on the chain...sorry for the confusion there... i always forget to hit the quote button... my bad there vinnie... my comments were only on the dual exhaust cam setup...
Old Apr 17, 2005 | 08:09 AM
BigVinnie's Avatar
I see I was kinda trippin for a sec on da question..... I thought all KA's are 20BTDC
Old Apr 17, 2005 | 08:14 AM
wikd240's Avatar
thats what i thought too... least i cleared it up...
Old Apr 17, 2005 | 06:48 PM
sweet whre is this picture located??
