need help asap radiator problem
when you replaced your radiator and refilled it did you remove the coolent burp
hole bolt its on the intake above the temp.
sensor??? if not that is why you are over heating. you have to remove the bolt so you can fill the hole systen. just fill the radiator untill you see water comeing out of the burp hole and bammm no over heating.....
You didn't tap the cooling system to get the air out!!!!!!!!!!
Use the FREAKIN search key at the bottom!!!!!!!!!!!!!
Look at the stupid bolt on the mani, NOW why was it put there???
uvamosk
08-12-2005 07:31 PM
240SX turbo
04-09-2005 01:05 PM
