oil pan removal
Old Mar 30, 2004 | 09:33 PM
sleighty's Avatar
Question oil pan removal
i know that in some cars you need to clear out a lot of things just to remove the oil pan, and in some cases drop the motor. is it possible to remove the oil pan on a 240sx with out removal of major conponents.... I want to clean and inspect it on my car...
Old Mar 31, 2004 | 01:08 AM
1. disassemble the front crossmember
2. unbolt the motor, lift it, and drop the sway bar a little
Taken from Sils post not to long ago. Search in the future.
Old Mar 31, 2004 | 05:00 AM
Sil40_Mayhem's Avatar
yep, yep, JynX is 100% correctamundo. i've searched here, on 240sxforums, NICO, and freshalloy, and they all unanimously agreed that those are the only methods. reason being, half of the oil pan is trapped in there by the crossmember. oh, and from my (ongoing) experience, getting it back it is gonna be a *****.
Old Mar 31, 2004 | 09:53 AM
You still havent got it back in!?
Old Apr 1, 2004 | 04:36 AM
well, i have neither a covered garage, nor a paved driveway. i get home from work like 20 minutes before the sun goes down, and it's been raining lately (not good for the jacking up of the vehicle on soggy ground). weather permitting, i plan to give it another go this weekend.
Old Apr 1, 2004 | 10:25 AM
Gatcha sil, must suck to wait all that time
Old Apr 1, 2004 | 10:42 AM
that it does, my man. that it does...
Old Apr 8, 2004 | 09:57 AM
Peas's Avatar
I hope the weather gets better for you man
Old Apr 8, 2004 | 11:51 AM
thanks, i appreciate that. well, the good news is that i finally got it back together this past weekend. the bad news is that it's still ticking. the only other minor problems i can hope for is blocked oil passages or a toasted oil pump. otherwise, it's a bent valve or lifter or something.
Old Apr 8, 2004 | 04:11 PM
dkdeleon's Avatar
the easyest way is to drop the crossmember and remove the moter mount bolts from underneath jack the motor up and the pan pulls out from the front very easy. hope this helps
Old Apr 8, 2004 | 04:48 PM
that would probably be the preferable way. w/the crossmember out of the way, the oil pickup won't be such a PITA. btw dkdeleon, thanks for the tip. i'm sure if it wasn't for u, i woulda long sense dumped gasoline on my oil pan and lit it on fire.
Mattyg2
Aug 22, 2004 08:24 PM
junk240sx
Feb 14, 2004 03:29 PM
nguy467
Oct 27, 2003 11:28 AM
Doba's240
Oct 6, 2003 04:47 PM
Doba's240
Sep 29, 2003 10:53 AM
