oil pressure
Old Mar 21, 2007 | 03:58 AM
dkdeleon's Avatar
oil pressure
The FSM states that oil pressure should be more than 11psi cold and 60 - 70psi at 3000rpm warm.
my oil pressure is at 50psi cold and 70-75psi warm, is that to high?
Old Mar 21, 2007 | 01:39 PM
dkdeleon's Avatar
"Tap" "Tap" is this thing on?
Old Mar 21, 2007 | 02:37 PM
Yeah that does sound a lil funky but how does the motor feel when its running? Maybe if its not running wierd, its not a huge problem.
Would you oil viscosity have anything to do with this?
lawl sorry i couldnt be of more help.
Old Mar 21, 2007 | 06:15 PM
sr91240's Avatar
check to see if you have coolant in your oil or oil in your coolant
Old Mar 24, 2007 | 12:44 AM
re037's Avatar
what oil weight are you running? is at normal capacity?
D Grade
Nov 29, 2005 10:00 AM
240riderr
Oct 14, 2004 11:18 PM
mango02
Feb 18, 2004 07:06 AM
ridesnowx4
Feb 12, 2004 10:11 PM
