Possible Valve Problem - Engine Repair or Upgrade to SR20DET
Old Dec 28, 2006 | 06:29 AM
redhorse64's Avatar
Overheating still!
I read somewhere that the STANT Thermostats are not good.
That is the type I purchased, at $12.
How about if I run the car with NO Thermostat to see if it is Overheating without the Thermostat?
And if it works, would it hurt to leave it that way? I mean without a Thermostat. Or should I go buy the cheaper $6 Thermostat?
Tomorrow will be 2 weeks that my car is unuseable.
Later,
Red.
Old Dec 28, 2006 | 03:44 PM
redhorse64's Avatar
Runs good with NO Thermostat
Well,
I removed the Stant Thermostat, put the Inlet Elbow back on without any Thermostat, filled the coolant system back up, and ran the car without any Thermostat.
Runs fine & does not overheat at all. Actually the heater works good too. It does take a little longer to warm up the car from cold, but that's ok for now.
I went to Advance Auto & ordered an "OEM Exact Replacement" Thermostat and I guess I will install it when I get it.
Thanks you guys for the all the comments and advice.
Take care,
Red.
Old Mar 31, 2007 | 06:25 AM
redhorse64's Avatar
RESOLVED a while back.
When I received the new OEM Thermostat I installed it. But more importantly, at the advice of a Radiator Repair Shop, I filled the system with 50/50 coolant, from the top hose. Yes, by removing the TOP HOSE at the radiator end & filling the system that way AND THEN using the little Air Purge Screw, I was able to get all of the air out of the system.
So, all is fine now & running great.
Sorry it took a while for me to get back here and post the final results.
Thanks again to all the people who provided advice,
Red.
ngcharleshk
West Coast/Hawaii
Jul 17, 2006 11:02 PM
uvamosk
Aug 12, 2005 07:31 PM
Little_Red_Rock
Jan 15, 2005 02:49 PM
NvS Altima
Aug 11, 2004 08:52 PM
Jonas
Aug 5, 2003 11:02 AM
