Problem with clutch padder
either your clutch master cylinder is bad or your clutch slave cylinder is bad... look for leaks at the firewall for the clutch master... and leaks on the passenger side of the transmission for the slave... fix which ever one is leaking and you should be good to go...
I've had that same problem. You might want to check the clutch fluid level as well. You could use the brake fluid DOT 3 (hydraulic fluid) as that works for the clutch. Once you put some in, turn your key two clicks then start pumping the clutch to get the air out.
uvamosk
Aug 12, 2005 07:31 PM
