oil on spark plugs?
Old May 14, 2004 | 05:29 PM
Craig577's Avatar
Question oil on spark plugs?
The last few times I have changed my plugs, I've noticed there is some oil on each one. My first thought was to replace the valve cover gasket and the 4 o-rings. I did this but it did not help...
What could be causing this, and is it a serious problem?
Old May 14, 2004 | 06:34 PM
tegg_gsr's Avatar
thats what i was going to tell you to do but im not sure(not enough experience)
Old May 15, 2004 | 01:00 AM
Ring problem?
Old May 15, 2004 | 06:59 AM
Craig577's Avatar
if it is a ring problem, is it pretty serious (likely to get worse and cause more internal damage)?
Old May 15, 2004 | 08:42 AM
BoogiepopJDM's Avatar
yea, if you ask me its the rings check it out it might be messing with your compression also. The rings are worn-out making it easy for the oil to seep in through the combustion chamber. Good luck bro.
Old May 15, 2004 | 11:19 AM
If its a ring problem, it can become a very serious problem later on down the road. As boggie said, compression test it. You know what you might want to use, its a product called Restore...search and you will find some info on it. Ive heard its great, and might help you.
Old May 17, 2004 | 02:39 PM
sage's Avatar
do a compression test AND a leakdown test, that should help figure out weather its your rings or a burned valve! but either way, getting oil on your plugs means a rebuild, be it a head rebuild/valve job, or bottom end/whole engine rebuild!
-sage
Old May 20, 2004 | 03:40 PM
Craig577's Avatar
I'm now noticing a slight power loss.
Thanks all for the info. I'll check it out ASAP
Old May 20, 2004 | 04:50 PM
sage's Avatar
and either a valve or rings will cause a power loss, due to loss of compression which can be diagnosed by compression and leakdown tests.
good luck!
sage
Old May 21, 2004 | 05:27 PM
Craig577's Avatar
Just wanted to clarify...
The oil is not on the bottom of the plug where the actual spark is. I figure if it was, the plug would not even spark at all or maybe I wouldn't be able to tell because the oil would just burn away.??? It is in the middle mostly right where the threading is and it's not completely saturated, but there is a noticeable amount on there.
I don't know if this makes any difference or not but just wanted to describe it more clearly.
Approximately how much will it cost to get a compression and leakdown test done?
Old May 21, 2004 | 06:17 PM
You can do the compression test your self, get a compression tester(30-60 bucks). Leakdown...not sure =/
Old May 22, 2004 | 09:20 AM
sage's Avatar
if its noticebly only on one side of the sparkplug and there is basically none on the other side, then you very likely have a bad valve guide/valve guide seal......which means taking the head of and getting a valve job, because doing just one valve is kinda pointless as the others could follow suite.....
-sage
Old May 23, 2004 | 08:48 AM
seem kind of weird cause you said you changed the v cover gasket and all o-rings. if it is a ring problem the oil is riding up on the walls of the combustion chamber a wetting the plug from the threads down. i hope i explained this correctly either way what ever the problem is you should get it checked out ASAP .
s14 gtst
Jul 23, 2005 05:36 AM
U_NeeKz
Apr 16, 2004 06:26 AM
doua
Mar 15, 2004 04:40 PM
sleighty
Feb 28, 2004 09:28 PM
drifterswanted
Dec 13, 2003 11:17 AM
