rought idle/stop
Old Oct 10, 2006 | 12:20 PM
d4rkpri35t's Avatar
rought idle/stop
any idea what could cause this... when i start my car either it'll die or idle between 300-500 rpms.. and sometimes when i go to stop it'll die on me especially between the 20mph to stop. i've taken off the throttle body and cleaned it, replaced my fuel filter... i replaced the maf about two months ago... idk what else could cause it... any advise could really help...
btw: s14a, ka24de
Old Oct 11, 2006 | 05:15 AM
dkdeleon's Avatar
check and clean AIV, its located under the hood on the drivers side next to the air filter box. in the FSM its called the pair valve.
Old Oct 11, 2006 | 09:50 PM
d4rkpri35t's Avatar
Alright, i'll check it out tomorrow, thanks for the help... i'll update tomorrow
Old Oct 12, 2006 | 10:10 AM
Zenki_SliderS14's Avatar
my s13 used to do that to...does your RPM drop below idle when the clutch is in to slow down?...my car has stalled a few times in cold weather because of this..
Old Oct 12, 2006 | 01:23 PM
d4rkpri35t's Avatar
naa, this is an automatic. my s13 does that though.. drops to about 400 RPMs but it doesn't stall..
Old Oct 12, 2006 | 03:18 PM
ryancoke9's Avatar
check your IACV, adjust the screw, if that doesn't work then take it apart, and clean it. It's located behind the intake mainfold, kind of tucked away.
1997 GA16DE
Sep 16, 2003 07:30 PM
240NSX
Jul 24, 2003 09:37 AM
sonic16
May 29, 2003 12:36 AM
Strizzy
Jan 16, 2003 12:55 AM
