seatbelt ecu??
Old Nov 11, 2005 | 09:26 PM
jdmbbic's Avatar
seatbelt ecu??
i was gutting out my 91 s13, and i wanted to know if you need to keep the seatbelt ecu? does it work for anything esc, other than the seatbelts? all i want is the harness for the lights and for the fuelpump.......
Old Nov 14, 2005 | 07:56 AM
apex760's Avatar
i have a 90 dont know if its the same stuff but make sure u close ur door an seat belts go up cuz they stop workin
Old Nov 14, 2005 | 12:01 PM
185db's Avatar
Should not hurt a thing to loose the seat belt controller. It does nothing but control the automatic seatbelts and also the seat belt light on the dash. I’ve done many swaps to normal seat belts in witch the controller was taken out, with no repercussions.
Old Nov 14, 2005 | 12:35 PM
nsn240's Avatar
i just unplugged mine... better than throwing it out... i guess it would help resale too
Old Nov 14, 2005 | 01:41 PM
Waynehead05's Avatar
i heard it weights like 30+ pounds
Old Nov 14, 2005 | 03:16 PM
nsn240's Avatar
what?? the little "ecu" you plug the harness into is about the same size as your regular ecu... i dunno if its that heavy though
Old Nov 20, 2005 | 03:55 PM
Joel SX's Avatar
removing your seatbelt ECU will create a cataclismic round of events eventually resulting in creating excesive amount of belt buckling and posible arm strain. other than that, you might as well remove the motors that move the seatbelt thing in the door, they are located behind the rear pasenger side panels (on each side). you'll have to figure out a way to make the seatbelt lock thing remain in its place. If you are removing the whole thing and using some 4 or 5 point harnes, then remove the whole thing. I'm guessing the ECU, some cables and the two motors will get you no more than 15 pounds off.
Old Nov 21, 2005 | 01:31 AM
185db's Avatar
Talking
That was freek’n hilarious! I just about shot coke out my nose. It caught me by surprise! Anyway I’ve always just welded a new bracket in place, mostly just to the B pillar. In most that I have done we did a roll cage and 4 or 5 point harnesses.
redfish
Jun 18, 2004 06:02 AM
Chedderknight
Jun 9, 2004 12:14 AM
anubis
Dec 13, 2003 02:18 PM
yiaracer
Oct 29, 2003 08:19 AM
SagxaZefiro
Sep 24, 2003 03:52 PM
