short throw s13
short throw s13
ok i got a b and m short throw shifter a while back and just got around to installing it. now i have searched all over and read all the forums about installing them and no one had a problem but me of course (just kidding) but the car is 14 years old, and the shifter was never even thinking of coming out. so now after i have removed the 6 bolts and actually went through the steps oh so carefully in the b and m instructions to "remove shifter" it dosn't want to come out. is there some sort of special thing i have to do? i have tried pry-bars, screw drivers, and alot of other things. just whenever i go and try to pry it out the whole transmission moves with it like its super glued together.
thanks,
sam
thanks,
sam
im in the middle of installing my obx shifter (what a b!tch) but i got the stock one out with no prob. what piont are you at the C clip is the only though thing i ran into and i used a pair of nidle noise pliers for that
well i got the old stock one out, but i cant seem to get the new one in. the white piece on the bottom that fits into the shift mechanism wont go in, i was thinking to switch it with the stock one, but cant get that off. also the gasket is crap on mine so i need to RTV silicon it.
thanks,
sam
thanks,
sam
Put the old shifter back in and make sure it is in neutral. I just installed a shrot throw shifter also and ran into the same problem. I put it in second to get some on the bolts out and forgot to put it back in neutral. When it was in second, the new one wouldn't fit. Once I put it back in neutral, it went in without any problems.
Adam
Adam
hey, i got it in, but its THE roughest shift ever!! i can see miss shifts happening..
i dont know if anyone else had this problem, or if i just need to work it alot to get into a good rythem.
supremesniper
Aug 5, 2007 06:49 PM
prostreetonline
Jun 20, 2004 01:15 PM
