Soft Clutch Pedal
Old Nov 27, 2003 | 01:47 PM
mr_lee21's Avatar
Soft Clutch Pedal
I just recently bought a 91 240 coupe. Had a rattle which was just a broken top timing chain gide bracket. Took it out, car is fine now. I did all the basic fluids like radiator and oil. Changed spark plugs, still has same plug wires, and there's some oil in the cylinders. I replaced the rubber valve gaskets. The clutch pedal is soft, softer than my 92 fastback w/hicas. Is this normal? Oh yeah, my 91 coupe is just the base model.
Thanks........
?How come there isn't a lot of hicas equipped 240s out there? My hicas light is on, can anyone help?
Thanks again.......
Old Nov 27, 2003 | 01:48 PM
mr_lee21's Avatar
Ummmm.....HAPPY THANKSGIVING TO EVERYONE!!!
Old Nov 27, 2003 | 02:27 PM
Hmmm...when you say its soft is it like it you have to put the pedal to the floor before it engages? HICAS wasnt very big...because it just wasnt
Old Nov 27, 2003 | 06:39 PM
Jonas's Avatar
The hicas was apart of the crem brule... it was the top of the package basically the most expensive model 240 you could have boughten back in 91-93... i found the sticker tag for when my car was at the dealership basically 10 years ago..lol what a classic..
as for your hicas light being on.. make sure you power steering pump isnt leaking any fluids, also make sure your reservoir has some fluid in it...
Old Nov 27, 2003 | 07:09 PM
mr_lee21's Avatar
The pedal is just softer on my 91 coupe than my 92 fastback. The clutch is still good, but I'm just wondering if this is normal. It's soft like the honda's.
Oh yeah, I started my coupe and my motor shook like crazy at about 1000 rpm, and when I revved it up past 3000rpm it went to normal and as it warmed up the motor was ok. Is it something I should worry about?
Old Nov 27, 2003 | 09:14 PM
Jonas's Avatar
2.4 liters you better be feeling a little zizzle lol think about it man... yeah its fine
and the soft clutch pedal... try cleaning out your slave clinder and get rid of air pockets in there.. basically flush it and make sure you flush it right... i love having all these cool tools to help me make life easy
Old Nov 28, 2003 | 03:39 PM
mr_lee21's Avatar
thanks jonas, i'll give that a try........
p.s.
i'm not a newbie, how do i get rid of the newbie thing?
Old Nov 28, 2003 | 03:42 PM
p.s.
After a certain amount of posts you can change ur title in ur User CP menu...yea. I forgot how many posts it is
Old Mar 15, 2005 | 03:45 AM
KAsingleC's Avatar
what about me? when I push the clutch pedal in there is a vibration in the pedal and when I engage the clutch (let out) theres a vibration throught the whole car including the pedal
Old Mar 17, 2005 | 06:43 PM
wikd240's Avatar
kasinglec that might be caused by a bad throw out bearing... not putting pressure all the way around on the pressure plate fingers... or the bearing could be ging bad and dragging... meaning there is no more lube in the sealed bearing... i dont know how much your abuse your clutch gets... but extreme heat can distroy the bearing rather quick...
Old Mar 17, 2005 | 08:48 PM
ProjectMy240's Avatar
you say the top timing chain guide broke.. did you get it out of your motor?
Old Mar 27, 2005 | 02:03 AM
KAsingleC's Avatar
thanks wikd240, I actually replaced my throughout bearing and the vibration continues. the wierd thing is it goes in and out, sometimes smooth and sometimes vibrates. I think the problem is bad motor and tranny mounts. I've got a sensor going out so the motor will run well and the not, its back and forth. the vibration correpondes with the engine running poorly. and yes, tones of abuse(pizza delivery)
chitodsr
Jan 5, 2008 12:34 PM
x3240racer
Mar 12, 2007 04:17 PM
speedyfox
May 13, 2005 12:27 PM
haipho123
Jul 25, 2004 11:15 PM
ryan15
Dec 27, 2003 12:44 PM
