SOHC cam journal wear
you are going to need 2 tools to tell if the cam and the head are worth trying to use again... you need a dial indicator and a micrometer... put the cam retainer back on the head and torque it down... with the dial indicator check the bore of the journal... match that to the specs in the fsm... if it is within specs have a machine shop clean it up ... mic the cam and see if it also is within specs... if it is usable then again have a machine shop polish the cam and you will be good to go...
if it is not within specs... search for the solid lifter conversion setup for the kae... it requires the machining of the cam journals for installation... once you have the conversion kit then have the machine shop do all the machining work needed and stick in a better cam and that will have you back to running with an upgrade...
other than that it is a new head and cam time...
Yah, I have bore gauges and micrometers, so I can check the clearances... I was just concerned about the surface finish on the journals more than anything else. Looks like some pretty good sized particles made their way in with the oil at some point.
98cwitr
May 14, 2005 01:13 AM
