Spray
Old Dec 1, 2004 | 04:34 PM
grindpunk16's Avatar
Spray
Well i am new to the forums so i dont know much about the ka24de or the ka24e. i was wondering big of a shot could you use on one of these engines. i have a 50 shot on my car right now and seems to be doing just fine with no ignition play. also if you have to use an ignition system which one do you recommend?
Jim
Old Dec 1, 2004 | 06:29 PM
franman s13's Avatar
if this is one an e engine and you havent moded the ignition or fuel systems yet your pry running extremly lean but your ecu/engine doesnt have a knock sensor so its not retarding timing at all even if its running lean. actually if you've got a good nitros system then it sould plug into your ecu and adjust everything acordingly.
Old Dec 1, 2004 | 07:23 PM
well the car im runnin is a 98 dodge neon with a 50 shot. no mpx ecu no dis-2 or 4 no fuel pressure nx kit with 50 shot. plus header intake and exhaust with udp. i was wondering if i could run a 50 shot pretty reliably on the 240
Old Dec 2, 2004 | 05:51 AM
hitokiri_808's Avatar
i think a 50 shot is as high as you should go on a ka with a dry kit. i THINK i read people doing 70-80 but i wouldn't trust it. expecally on an old engine with a crap load of miles.
Old Dec 2, 2004 | 12:13 PM
it wouldnt be a dry kit. i dont really trust dry kits. its a nx wet kit
Old Dec 3, 2004 | 02:23 AM
should be safe then, if engine is in good shape. i been looking around for a 50 wet shot for me. figure it can hold me off until i can afford a engine swap.
Old Dec 3, 2004 | 07:42 PM
i was thinkin of either sprayin the engine or doin a ka-t
tmptazn27
Dec 21, 2004 12:09 PM
slow240sx90
Dec 2, 2004 07:26 PM
E Spin
Sep 2, 2004 04:34 PM
chi sin lo
Feb 29, 2004 08:34 PM
Jonas
Feb 10, 2003 08:26 PM
