Start damn it, START!!!
Old Dec 5, 2004 | 07:25 PM
Slidin240's Avatar
Unhappy Start damn it, START!!!
I own an '89 nissan 240sx hatchback and i got it dirt cheap ($100 ) and its not turning on. the previous owner didnt tell me whats wrong with it. It turns over but not starting and i changed the spark plugs and cables. Theres gas going in the engine and the spark plugs spark but the car doesnt turn on. What could be the problem? I know u guys can help me with this
Thanx in advance
- Golam
Old Dec 6, 2004 | 08:46 AM
slo9012Vde's Avatar
well from reading and consulting with a few friends.
heres a list...
1 timing could be off
2 wrong firing order
3 fule injectors could be bad
4 distributer coil could be bad
5 chance with CPU (AF ratio)
6 is the clutch down? lol just incase....
7 alternator fuse
8 bad ground
those are some things to think about..
with number six, not to call you dumb, but i have known a few that have tried to start manuals with the clutch not down! sorry.
thats all for me..
-slo
Old Dec 6, 2004 | 02:29 PM
Slidin240's Avatar
Thanx ill try that if anyone has any other ideas please post
p.s. the car is not stick plus i kno to push the clutch down lol
and what do u mean by LHD 240sx? wat does LHD stand for?
Old Dec 6, 2004 | 03:54 PM
rivneo1's Avatar
Exclamation
LHD Stands for = Left Hand Drive
btw hey make sure that the fuel pump is working .Check ur compression ,battery is it dead? fuel filter make sure is not clogged !,Check the MAF sensor ,make sure that thing works!
Make sure every sensor on the MAF and everything else on the car is plugged!.See if the ECU give u any codes that may help.
Just my 02. cents
Old Dec 7, 2004 | 02:57 AM
Whisper's Avatar
not to mention to check u'r hoses... make sure u don't have a vacume leak... had one of those on my 91 240sx.... fixed the prob.. and doin good up till a few days back... if u read my thread i posted earlier u'd understand...
oh... and my brother bought my car for 100 bucks.. i put in a 35 dollar starter and drove it off the guys lot... when she started u should have see that guy walk inside and slam that door... so far the only thing i put in it since then is a clutch. and spark plugs.. that's it....
leiferik1
May 30, 2003 02:48 PM
nissean
Mar 25, 2003 10:31 AM
Strizzy
Mar 9, 2003 12:07 AM
nguyenmk
Nov 3, 2002 03:54 PM
RNN14
Feb 7, 2002 06:29 PM
