sudden loss of power
Old Apr 15, 2005 | 11:06 PM
re037's Avatar
hey guys, decided to ask for some forum assistance on this lil prob. well my car has a rough idle to begin with due to bad injectors (currently saving up for some rebuilt ones). anywho. today i was driving it to work and it was a lot rouhger than anything ive experienced. the car felt like it was about to stall and die plus it made nearly no power. the engine wouldnt rev up at all past 3k and acceleration was worst than a bicycle. any ideas?
edit: new plugs, oil, air & fuel filters and 02 sensor. car is stock
Old Apr 15, 2005 | 11:30 PM
Waynehead05's Avatar
do you have an intake?... what filter?
Old Apr 15, 2005 | 11:34 PM
re037's Avatar
k&n drop in. fresh oil, and new filters (oil, fuel & air) is what i meant. are you thinking bad maf?
Old Apr 16, 2005 | 06:55 PM
dkdeleon's Avatar
check maf and fuel pump and vacuum lines
Old Apr 18, 2005 | 02:17 PM
tallic_red240sx's Avatar
Your alternator may be taking a dump, could be the alternator belt also...
Old Apr 18, 2005 | 02:18 PM
Im also thinking it could be your ignition coil possibly.
Old Apr 18, 2005 | 02:54 PM
naptime's Avatar
check your plugs cuz mine did that. scroll down on this thread and see for yourself http://www.club240.com/forums/showth...&pagenumber=57
Old Apr 25, 2005 | 11:46 AM
re037's Avatar
plugs are fine, so is the fuel pump it hink. also the car has recently been having a hard time starting. so any other ideas?
Old Apr 25, 2005 | 11:48 AM
re037's Avatar
oh yeah anyone care to point out where the ignition coil is located or how it looks like
Old Apr 25, 2005 | 06:47 PM
wikd240's Avatar
the coil is on the drivers front shock tower... follow the spark plug wire comming out of the center post on your distributor to where it plugs into the coil... that is where you will find it...
Old Apr 25, 2005 | 06:53 PM
re037's Avatar
cool, thnx guys youve all been very helpful. ill be sure to check back if i dont find the culprit
Old Apr 26, 2005 | 02:11 PM
re037's Avatar
ok guys, well i replaced the igniotn coil with one off my "parts car."
well it was running for a day and today the car did not want to start at all. how do i chekc the fuel pump? i have no pressure guage. can i just open the line after the fuel filter and see if it guhses out fuel when i try to start it. i know its not exactly safe but at this point i ill try anything
Old Apr 26, 2005 | 02:16 PM
Abo1787's Avatar
my car did that too i went in and my alternator belt had been worn out and when i pushed past 3k rpm it slipped and it started screaming and it eventually just wouldn't run i lost my sound, lights everything and when that alternator wont charge that battery, bad things happen like .... way bad
Old Apr 29, 2005 | 02:14 AM
s13gonwild's Avatar
Its your alternator. My car did the same thing changed it and problem fixed, I also went threw the touble shooting of replacing cap and rotor, but it ended up being a bad alternator
Old Apr 29, 2005 | 02:46 AM
wikd240's Avatar
befor you start swappin alternators... does the car crank over or does it just click... if the battery is always dead then i would go with the alternator...if it cranks over then i would think of other things besides the alternator... if the alternator was bad or going bad you would have a drained battery all the time...
to be honest with you befor you can even start to troubleshoot all of the problems you need to fix the bad injectors... that is the first step in trying to cure a rough run situation... the fuel injectors could be completely bad now...
a safe way to check your fuel pump is to turn on the key... do not try to start ...and listen for it to hum... it will run for a few seconds when you frst turn the key on... i would suggest having someone turn on the key while you are standing at the back of the car by the fuel fill door with the gas cap off... you will hear the pump run for a few min then stop... thats what it is suposed to do...
from there if it works then it shold be fine... if not then you have a problem there... but you still need to fix the injectors befor anything else...
