is this swap possible?
Old Jan 13, 2004 | 06:15 PM
auto240's Avatar
is it possible to swap the dohc head from a 91 onto a sohc car from 1990?
Old Jan 13, 2004 | 06:20 PM
95_240SXSE's Avatar
I believe it is but I'm not sure.
I know that SOHC pistons will fit into a DOHC bottom end, so I would think that the head swap would work.
Old Jan 13, 2004 | 07:03 PM
Yea..i think solol
Old Jan 13, 2004 | 08:02 PM
NcTwOfOuRtY's Avatar
I believe it would arent they basically the same engines just one dual and one single cam?
Old Jan 13, 2004 | 09:22 PM
rayaapp2's Avatar
some one posted their attempt of this a while back somewhere. They were not completly finished but the only known complication was that the lower chain tensioner was blocked by a peice of the block. They said they just had to machine(grind) it off.
It didn't look real difficult as it was basically just the KA24E Block with al the KA24DE parts attached to it.
Old Jan 14, 2004 | 06:52 PM
rudeboy's Avatar
yeah, it works.
just mix and match pieces.
Old Jan 18, 2004 | 12:23 PM
auto240's Avatar
is it worth it. i mean will the gains be worth it or no?
Old Jan 19, 2004 | 04:24 AM
After all is said and done (parts, labor, mix-n-match headaches, etc.) I'd think it would be cheaper and easier to just get a used KA for $200-$300 instead.
Old Jan 19, 2004 | 06:02 PM
auto240's Avatar
yea but my ka only has 52k. im not gonna find one with 52k for $300 bucks. im not sure. im gonna be either turboing my ka or just gettin a sr20det
Old Jan 20, 2004 | 09:07 AM
drnovascotia's Avatar
so go KA24E, people have done it. with 52K you could go without rebuilding if you ran 6-8 psi if the compression is good.
Dr.
BigVinnie
Jan 27, 2005 04:58 PM
deloesian
Nov 24, 2004 05:16 AM
mmbd
Mar 31, 2003 01:25 PM
ccchen
Nov 29, 2002 08:19 PM
flarearrow
Feb 14, 2002 01:12 AM
