tach help!
Old Oct 24, 2006 | 05:34 PM
Christpher's Avatar
Question tach help!
i will try to make this short and sweet...
i have a 96 240sx that has a broken tach, so i bought an external one to replace it. the tach i bought has a total of 5 wires: 2 power (red), 2 ground (black), and i tach signal wire (green).
i hooked the power and ground up right to power the tach, because when i iturn the ignition to accl the needle will move a litlle.
i hooked the power and ground to the gauge face up right, because when i turn my lights on the gauge turns blue.
but the signal wire was hooked up to the black wire that is traced with red that is in a harness on the side of the distributor cap.
so whats wrong? what do i do?
appreciate it
newbie
Old Oct 24, 2006 | 06:35 PM
Zenki_SliderS14's Avatar
shouldnt there be a Red(Power)Yellow(Batt+) Blk(Ground) and Green( Signal Wire)?
Here what i did. I spliced the power cables off of my radio and got Tach Sig wire from Ecu Pin 3 Should be a yellow/Red wire.
Old Oct 24, 2006 | 06:51 PM
Christpher's Avatar
well, i checked my service manual to see about the #3, and it is to the tach. so hell yeah, i will try that tomorrow. to see if it works!
Old Oct 26, 2006 | 06:33 PM
Christpher's Avatar
appreciate it...
thanks, the advice solved my problem!
Old Oct 26, 2006 | 07:04 PM
no prob..
nvrstock
Oct 13, 2005 09:51 PM
geforce69ultra
Aug 17, 2005 12:32 PM
Down_Shift21
Mar 23, 2005 11:49 AM
rkcarguy
May 21, 2004 11:43 AM
rps13
Apr 10, 2003 12:48 AM
