tapping noise=bad?
Old Oct 7, 2002 | 09:24 AM
drifties151's Avatar
tapping noise=bad?
ok i have had my 95' 240 for about 6 months and from the day i got it, there has been a tapping noise. its coming from the area of the timing chain. It hasn't got any worse since the day i brought it home, does anybody else have this noise? i had the valve cover off changing the gasket but i couldnt really pinpoint the origin of the noise w/ it on. i do know it's coming from the front of the valve cover though.
Old Oct 7, 2002 | 09:53 AM
Import Fanatix's Avatar
I have that same noise in both my 240's. I thought that it was a valve issue. I know they are some issues with the timing chains in these cars, but don't know if that is the noise.
Old Oct 7, 2002 | 11:28 AM
i thought it was a valve knock at first too, but when i took the valve cover off too see what was located in the front of the head, its just the timing chain and this metal box(i guess is a chain guard of some sort). i'm going to see if i can mess around with the tensioner. If after i tighten the chain up and it still makes the noise im gunna get stillen cam sprockets and a new timing chain to see if it fixes the problem, it's starting to get on my nerves. any other opinions out there?
Old Oct 7, 2002 | 11:46 AM
malicex000's Avatar
u should talk to rudeboy... he did that whole timing chain thing... or he got a mechanic to do it... his car wasnt working until he got that done.... he would have experience with this area...
Old Oct 7, 2002 | 11:53 AM
well i know from courtesynissan.com that they revised the whole timing kit with the guides, so it might be the problem, but i'm scared of whose going to do it. Its a lot of work to do.
Old Oct 7, 2002 | 12:25 PM
malicex000's Avatar
i heard it can run close to 700-1000 to do it... i had tapping noise... and now its not there anymore for some reason.... maybe its becuase its getting colder... im not sure... but my tranny is almost done... can that effect it ?
Old Oct 7, 2002 | 03:30 PM
They revised the whole timing kit? this is important, it might save me alot of time and trouble. in my searching i've come across this special type of camshaft. is there an upgraded exhaust camshaft for the DOHC motor? its pretty wierd, all the sites i have went into don't say much about it. ANYWAY, back to topic, do you know where i could get some more info about this revised timing stuff?
BTW, here's a link with the little thing about the camshaft...
http://www.courtesyparts.com/Merchan...de=99996-00048
Old Oct 7, 2002 | 03:38 PM
malicex000's Avatar
http://www.geocities.com/MotorCity/L...1/EM89-002.htm
Old Oct 7, 2002 | 03:56 PM
thanks for the info malice, but I have a 95 with the KA24de motor. all that stuff was for 89 ka24e. would those directions still help on my motor?
Old Oct 7, 2002 | 04:06 PM
malicex000's Avatar
well someone correct me if im wrong... its still a ka engine... alot of things would be similar... wait till more people respond...
Old Oct 7, 2002 | 04:40 PM
I think the issue affects both the e and de motors. That bulletin is only for the de motors, but they redesigned both timing chains.
Old Oct 7, 2002 | 05:12 PM
rudeboy's Avatar
the infamous timing chain thing.
there is a little sumthin out there for the dual cams.
i did mine(twice) in my driveway with normal hand tools. not a real hard job, just a pain in the ***.
if you're hearin a tapping sound then your tensioner might not be functioning properly. if you pull all the accesory stuff off(power steering , fan, all belts,and brackets) then set engine to TDC pull distributor, oil pump. remove the 4 front oil pan bolts, and losen the next two( behind the removed ones -one on each side) you should be able to pull timing cover off. (don't forget the crank pulley) then you can inspect. thats gona be the olny way to really check and be sure.
i'm not sure how well cam sprockets will help quiet up things.
it's surgery time. if you dont check it soon it could get BAD, TRUST ME.
the job is expensive, do it your self.
Import i'll do yours
the new driver side guide isn't 100% plastic anymore. thats like the olny change to the kit for single cams
go HERE see how that works
Old Oct 7, 2002 | 05:21 PM
wow, thanx alot all you guys for your help... i didn't know half that stuff... i guess i have another project car on my hands (RIP rps13). thanks once again, ill be sure to keep you all posted on how it goes down.
Old Oct 7, 2002 | 05:26 PM
StanBo's Avatar
I will be doing mine when I get the house. I want to have light and not have to rush. It seems like a straightforward job.
Old Oct 7, 2002 | 05:35 PM
rudeboy's Avatar
the job is really stright foward.
the first tine i did mine it took about 10 hours. then i had to adjust some things( cuz i got a little careless) it olny took like 4 hours.
StanBo i'll do yours too. holla at me.......
