will a altima radiator fit?
Old Jul 13, 2004 | 12:14 AM
WILDACEXXX's Avatar
yea will it fit a s13? i had a 94 altima and im planning on using the dual electric fans so i'd thought that i'd use the thicker altima radiator if possible.
Old Jul 13, 2004 | 10:10 AM
Is the inlet and outlet the same?
Old Jul 19, 2004 | 12:19 AM
devnull's Avatar
Aside from the size and mount locations, you also you need to take into consideration the location of the drain hole, and the direction that the overflow outlet is facing.
Old Jul 19, 2004 | 09:32 AM
WILDACEXXX's Avatar
i looked at a altima rad the other day. the outlets are in different positions (like a sr rad). didnt go under the car to check the drain hole but the overflow outlet is facing the same side as s13's.i talked to my friend and he said that i might need special hoses and it wont be as good because they wont be the same. is it really that bad of idea to get radiator hose and to make the rad fit?
CValle86
Sep 30, 2005 03:25 PM
OTB Race Team
Mar 25, 2002 09:30 AM
s14vaxlr8
Feb 25, 2002 05:23 PM
Chas
Feb 9, 2002 01:09 PM
