maf on my rb26?
Old Mar 8, 2009 | 04:05 PM
turbojoe's Avatar
maf on my rb26?
Can I run a single maf on my rb26? I have head that a 300zx maf will work. I just dont like running two mafs because the intake looks like ****. It is a Y pipe intake and it is ugly and takes up too much space. thanks for any help
Old Mar 8, 2009 | 11:11 PM
240smoke's Avatar
I think if you get a stand alone fuel management system, you can switch to MAP. It will go somewhere after the turbo and before the throttle.
Old Mar 9, 2009 | 02:32 AM
HKST04Z's Avatar
as smoke said if you switch to a map sensor its possible to run no maf. if your running a single turbo i would keep the twin maf's because if you try to use only one it might freak out a bit because of all the air and voltage being shoved into 1 as opposed to 2. just switch to a map
Old Mar 12, 2009 | 04:22 PM
turbojoe's Avatar
Ok, I guess I will stick with the dual setup for now. Thanks for the help fellas
Old May 6, 2009 | 05:28 PM
gismonismo's Avatar
Banned
you should go with Map then.
turbojoe
Mar 1, 2009 04:37 AM
DriftX
Jul 3, 2007 04:13 PM
Dres240
Nov 9, 2005 06:27 AM
AceInHole
Feb 5, 2004 07:23 PM
wrxhall
Apr 10, 2003 02:17 AM
