Road Race/AutoX If you like road racing, autoxing, or track events, then this is the spot for you.
Auto-X suspension
Old Oct 22, 2004 | 01:25 AM
Jack The GTR's Avatar
Auto-X suspension
hey all whatsup. i need help with an ideal suspension setup for auto-xing. the suspension shal be for a S14.im not into mad tyt3 JdM drifting y0! id rather grip then fly into a wall and ruin my investment. im pretty new to all the suspension stuff so can i get a list of all the components i would need. please help me if you can. ive searched most of the 240 forums and came up with nothing. i appreciate it if you can help me
Old Oct 22, 2004 | 04:07 AM
ArticDragon's Avatar
struts/springs or coilovers, sway bars, strut bars, pillowball upper mounts, pillowball tension rods. Best I can come up with. Raine can prob give a more extensive list.
Old Oct 22, 2004 | 09:04 AM
Lose weight!
Old Oct 22, 2004 | 11:03 AM
Catharsis's Avatar
what class?
Old Oct 22, 2004 | 01:02 PM
hmm im not sure what class,i will run mostly stock engine components tho..SOLO1 or 2? im not sure
Old Oct 22, 2004 | 03:36 PM
Catharsis's Avatar
umm solo1 and solo2 are the type of compition... check out the rule book
Old Oct 22, 2004 | 07:49 PM
As cath said, read the rule book for solo2 and 1. See what class you will be running, what modifications are needed to run other classes and etc.
Old Oct 22, 2004 | 08:59 PM
^^^ Anyone know anything about Kie Office stuff?
Old Oct 22, 2004 | 10:44 PM
Waynehead05's Avatar
2,$$$... very...very good quality.
Old Oct 23, 2004 | 10:06 AM
hard part is, there's no rulebook available unless you go to an event to buy one... unless someone can find a current rulebook online (which I've tried to search for with no results)
...just how serious are you about Auto-X in the first place? If you're pretty new to susp. like you said, then maybe you should research more as to what each component does for you and your car, instead of going out and buying a bunch of suspension stuff and slapping it all on the car without knowing how to ajust or tune all the stuff. Knowing what each part does will help you understand more about suspension, whether you auto-X or not.
BTW even with just a set of high-perf. tires on a stock car will get you around the course pretty good.
Old Oct 23, 2004 | 03:24 PM
Catharsis's Avatar
Kei office has nothign to do with autoX keep it on topic.
Old Oct 23, 2004 | 08:23 PM
jmauld's Avatar
If you're new to autocrossing, the best advice is to leave it stock.
Run in Stock class (GS) with a set of Koni's, upgraded front swaybar and good tires. You'll learn more about driving this way, instead of spending time adjusting the car to cover up for driving mistakes.
Here are the legal mods for GS:
Struts/shocks
cat-back exhaust
plug wires
Any OEM style air filter (must keep box intact)
Front Swaybar
EVERYTHING else must remain stock.
Old Oct 23, 2004 | 08:31 PM
d4vech3n's Avatar
drifting, autox, gymkhana, and circuit cars have pretty much similar suspension set ups. Basically making the car more stable and predictable. When suspension companies start adding "Drift Spec" to their products, it doesn't mean much since they're not much different circuit, gymkhana, etc. it's just a marketing tool. Kei Office specialize in suspension, not just "drifting" suspension. They make some of the best products so their prices are high. If you want top of the line, Kei Office, Zeal, and Apex'i are probably the best althought alot of their higher end products are designed for track use only.
Old Oct 24, 2004 | 06:34 AM
NoCones's Avatar
http://www.moutons.org/sccasolo/index.html
Old Oct 26, 2004 | 07:52 AM
I stand corrected
Bernie (NoVA)
Apr 3, 2012 07:34 AM
Bernie (NoVA)
For Sale - Part Outs
May 11, 2009 08:59 PM
Tosh
Oct 15, 2003 08:25 AM
Sizzzoooo
Mar 11, 2002 01:56 PM
Altimat
Feb 27, 2002 12:36 PM
