got a 90 240sx but...
Old Mar 30, 2004 | 06:17 PM
boostedfury's Avatar
I bought a sr20det to put in it, the motor will be here in two weeks. I have a t3/t4 to put on it but I don't know hardly anything about these motors. What can I expect out of this motor? I am shooting for low 12's in the quarter, I got a Jspec rearend for 500.00 to slap on when the motors in and done. I just went from front wheel drive turbo to rear wheel drive (soon to be turbo) Plus I have a e-manage to put on this car so tuning should be a breeze. I just want some realistic numbers for this motor. By the way out of curosity what does my car run with a cat back exhaust? I am a skilled driver as I have won a couple bracket races. Thanks everyone.
Old Mar 30, 2004 | 08:42 PM
Welcome
Not to sound like a dick or anything, but I wouldnt buy a car/engine if I didnt know what I was getting myself intoa nd what to expect. Just my 2 cents. What PSI are you going to be running, upgrading the fuel injectors?
Old Mar 31, 2004 | 02:50 PM
I am familiar with turbo motors as my last car was a turbo running 15 lbs. On this car I was planning to max out the duty cycle of the injectors, I believe they are 370 cc injectors. I inmagine I will top out the injectors around 10-11 lbs of pressure before they need upgrading. If there are any quirks or things about this car that ya'll feel the need ti inform you of by all means let me know.
Old Apr 2, 2004 | 12:45 PM
areitu's Avatar
Umm...well, bracket racing's coo, but it happens in a straight line. In RWD vehicles, the rear end moves around when you give it lots of gas or when it's wet. Well, on the bright side, you'll have muuuch better weight transfer. You should ask the performance or engine section as to what kind of times your setup should run. My best guess, and don't quote me at all or take my word as final, but your setup looks like a 14-13 second setup.
Don't run your injectors close or at max duty cycle unless you don't really care. Z32 300ZX fuel injectors fit. Exhaust and boost controller should bump up your times a little bit. If you're bracket racing all day, you might want to upgrade your intercooler at the same time.
uvamosk
Feb 21, 2006 09:13 AM
grn98lude
Jun 24, 2005 02:28 PM
Whisper
Nov 15, 2004 12:33 AM
Sil40_Mayhem
Oct 30, 2003 11:22 AM
Turboed240
Oct 6, 2003 04:59 AM
