****SR20DET Z32 Brakes silvia front end
Please call me only im on so may forums it gets confusing 704-746-4468 Alex
everything listed can be shipped if you pay shipping unless we work a deal other wise
I have lots of parts black interior parts if you want some call me and we can work something out
Z32 50mm calipers front and rear and e brake assembly with skyline rotors $600
J30 Vlsd $250
Silvia Front end coversion Fenders hood bumper triple projectors corner lens and silvia center peice $950
S13 cluster with heads up display $100
Silvia Rear truck lock $60
Toyota CT26 (mk3 supra) turbo Rebuilt $250
All S13 SR20DET parts
Redtop Short Block $450
Bear head $200
Valve cover (custom purple) $150
Stock intake and exhaust cams $100
Stock Cam gears $10
Valve $40
Valve Spring $50
Intake Mainfold $100
Coolent Tube $10
Front timing cover $70
Cam shaft caps $50
Pistons and rings $80
Crank shaft $120
Rear cover $15
Flywheel bolt $20
Lower Oil pan (perfect still has sticker) $40
Upper oil Pan $90
Alt. $60
A/c Pump with bracket $110
S13 Seats black with no rips one peice seats $100
#62 ecu $100
Full wireing harness $280
trans $150
4 teardrop wheels with tires $100
S13 Hood $50
S13 hatch taillights $90
turn signals $10
Lower grills $10
Radiator $20
Downpipe $20
2 sohc maf $20 a peice
1 dohc maf $50
J30 Vlsd $250
Bear head $200
Stock Cam gears $10
Valve $40
Valve Spring $50
Coolent Tube $10
Cam shaft caps $50
Crank shaft $120
Rear cover $15
Flywheel bolt $20
Upper oil Pan $90
Alt. $60
#62 ecu $100
trans $150
S13 Hood $50
turn signals $10
Lower grills $10
Radiator $20
Downpipe $20
1 dohc maf $50
Juiced
Apr 2, 2008 11:39 PM
Carparthookup
Nov 19, 2005 07:01 AM
