Redline Intercoolers
Redline Intercooler -600*300*76
Product Description:
- Polished aluminium
- Core size 600*300*76
- 770mm over all length
- 3 inch (75mm) inlet and outlet
- Compressed air flow rate of 750 cubic - feet/min
- Suits most turbo cars.
Good for up to 600HP (450KW). Low pressure drop 0.2psi at 15psi. Strong bar and plate design tested to over 80psi. It has a very small pressure drop across the end tanks, at 15 psi the outlet shows 14.8 psi with a temperature drop from 120 degrees to 28 degrees
REDLINE INTERCOOLER
Awesome core to make a custom front mount kit
450*300*76
Product Description: medium aluminum polished intercooler. it is a bar and plate type cooler with core size of 450x300x76 and 3" inlet/outlets. overall leght is 630x330x76mm
designed for huge air flow, with results showing atleast 15hp gained from replacement..Proven in performance
SIZES AVAILABLE:
600*300*76 $300
550*230*65 $250
450*300*76 $200
EMAIL ME AT ANDRE.REDLINE@GMAIL.COM
REDLINE INTERCOOLER
450*300*76
SIZES AVAILABLE:
600*300*76 $300
550*230*65 $250
450*300*76 $200
