Digital Speedometer
Old Mar 8, 2006 | 12:52 PM
bareajass's Avatar
Unhappy Digital Speedometer
So I just got a starter installed in my car after it left me stranded in the middle of nowhere, but after it got installed, my digital speedometer went out and the mechanic really didn't know what happened (nor did I ). Would anyone know anything about how to fix this, how much it costs, how much time, etc.??
Thanks
P.S. It's a 1992 240SX SE
Old Mar 8, 2006 | 01:28 PM
soldierdude262's Avatar
All I can think of is to check fuses and use a volt meter to see if it's getting power.
Old Mar 8, 2006 | 03:09 PM
Gearhead_42's Avatar
When you drive, does your odometer work? If not, check the wiring from the speed sensor at the back of the tranny up into the main harness... It runs right past the starter, easy to bump/damage...
Old Apr 4, 2006 | 08:43 AM
treebob's Avatar
Did you find the problem with your digital speedo? I have the same problem but on a 91 240SX SE. Anyone know where I can get a wiring diagram for this series?
Old Apr 4, 2006 | 12:05 PM
bareajass's Avatar
Yeah, I did get the problem fixed. Apparently, it's a part that costs about $185, but I'm not sure what the name of the part is because my brother's mechanic knew right away what was wrong. Unfortunately, he did not relay the part name/information.
Old Apr 6, 2006 | 09:43 AM
treebob's Avatar
well, it's not the speed sensor on my car, i hooked it up to a voltmeter and took it for a drive and it worked fine.
Now I have to get to the head-up display computer and assume to do that I have to remove the instument panel/glareshield assembly. Anyone have any tips on removing this?
Old Apr 27, 2006 | 07:19 AM
NeuAgeRacing's Avatar
i just removed the dash and panel/glareshield.. i wrapped my dash in vinel if u need a HUD computer contact me i got a extra
Old Apr 28, 2006 | 02:06 PM
treebob's Avatar
Thanks for the help, and to the guy that took his post off. I was on the road and have only just got back and now have the instrument cluster out. I've checked for voltages and signal from the servo, all good, so it's looks like a duff speedo.
NeuAgeRacing, do you have the complete instrument cluster for sale or just the HUD computer?
Old May 4, 2006 | 06:16 PM
a_ahmed's Avatar
So it doesn't work at all?! Or... it works sometimes?!...
If it works after car warms up then it might be one of the capacitors.
Check this out:
http://multi-index.myonlinesite.com/...0sx_speedo.htm
Old May 6, 2006 | 03:21 PM
treebob's Avatar
When the gauge or the battery has been disconnected for a while then reconnected, it lights up when the key is turned to the 'run' position for about 3 seconds then fades away. It doesn't come back on when the car has been running for a while or after I heated up the capacitor.
v8killa
Jan 8, 2006 07:04 PM
lrgkevin
May 23, 2005 07:40 PM
lrgkevin
May 22, 2005 02:34 PM
papakiet
Nov 16, 2004 07:27 AM
defeated26
Nov 7, 2003 01:00 AM
