s13 turbo kits ?
s13 turbo kits ?
i've been looking around the threads and i couldnt really find if anyone knew about a turbo kits for an s13.i've seen nsport's but im not sure if they do that for s13's as well.and i've been wondering if the 95-98 kit will fit on a 91 s13.im open to suggestiuons and anything else.
for the nsport, they based the prototype model ON the s13. If you go to their website www.nsport.com you can see the car they used is a s13.
In 91, did they have the ka24e or ka24de? If ka24e, then check out this guy www.gladmanperformance.com he makes turbo kits for the ka24e and he has clips of it in action
As long as your engine is the dohc, those later model turbo kits will fit, you just won't be able to use certain stuff such as ecu upgrades that come with the kit. I think i've read threads that show how to get around that and all. But since your car is most likely obd-I , and later models are obd-II, you just won't get to use the ecu upgrades (greddy e-manage for greddy turbo kit) unless you do some electrical working around that to make it compatible.
but blah, you dont need that crap necessarily, just get the nsport turbo kit, or piece a turbo kit together.
You could also check out www.import-autoperformance.com
Aero Designs
Sep 3, 2010 02:52 PM
