yea.....
yea.....
so like.. there's this rattling noise going on in my car.. i left my car running, lifted the hood, and i can hear the rattling.. it sounds like a bolt or screw or some **** and its really bothering me.. any ideas?
lil more specific.
from the motor?
if so check the timing chain. They tend to rattle alot on high mileage KAs. The usual solution is to A) remove the upper timing guide or B) just redo the whole timing system. A is the usual answer to the problem tho.
from the motor?
yah.. my friend said that it can be my timing chain. and on the other hand, some dumb *** mechanic drove by me one day while i was trying to figure it out, and he said it was my engine mounts, my but engine aint even shaking.. soi doubt its that..
also, my clutch... is like... not normal.. HAHAH. its like.. it feels sticky, when i press is its not smooth, and when i release it, its like sticky, feels rusty, kinda creeky. if i press down on the clutch and release my foot fast enough my pedal stays down and comes up about almost a second later.. new clutch? or does my car just ****ing suck.
For starters, you need to be more specific when posting thread subjects. "yea....." doesn't really say much about what you're trying to figure out, or what this thread is about. Secondly, you need to post this within the right section. Last, you need to search because this could be a number of things (i.e. Heat Shield, Timing chain, etc.) I am positive those issues have been covered if you search.
Good luck with the problem.
