i have 2 questions
Old Jan 29, 2006 | 09:03 PM
kugai's Avatar
i have 2 questions
i have a 95 240sx and i was wondering how to lean my headlight lens from the inside. i know hwo to take them out but i dont know where to take a part the lens. i searches some topics but i didnt read any on how to take apart the lens. sry
Old Jan 30, 2006 | 03:25 AM
You will have to heat them up (heat gun, oven) to soften the sealant and then you should be able to take the lense off.
Old Jan 30, 2006 | 10:07 AM
kugai's Avatar
the headlights have little metal brackets should i take them off? the heat the them up? thanks
Old Jan 30, 2006 | 03:25 PM
Levi SPL S14's Avatar
^ thats ****ing commen sense.
Old Jan 30, 2006 | 04:38 PM
nightkid86's Avatar
take the clips off then stick em in the oven, work on em, then before closing them up put them back in the oven heat em up, take em out and put the clips back on
Old Jan 30, 2006 | 05:52 PM
what exactly is "leaning the lense"
you mean aiming? there are adjustment aparati on the back of the housing. 8mm socket
now if you want to remove the lense 250 degrees cover lense with foil and do for around 10 mins. use a butter knife to break the seal and you should be able to pull it off with your hands
Old Jan 30, 2006 | 05:55 PM
I think he meant clean instead of lean
Old Feb 20, 2006 | 03:41 PM
shift.obsession's Avatar
-_- if u want them clean use Mother's Aluminum Polish, wipes the cornbread look right off the lense but seriously...topic has been covered numerous times...
josh240caseysx
Oct 6, 2006 02:30 PM
Kens_s13
Dec 30, 2004 03:14 PM
DRFTFC3S
Jun 9, 2004 02:47 PM
yoshio006
Dec 28, 2003 09:35 PM
JPierce
Nov 20, 2003 05:39 AM
