Interchangable seats
Ok, I was wondering if the interior of an S14 could be swapped into an S13. I've seen an S13 with S14 front seats but is that custom work or just plug and play? What about the back seats too. I'm talking about a Fastback here also. Thanks for your info.
hmmm... i can't remember what performance mag i was reading, but it said that s13-15 all use the same seat mounts, so it's plug & play. (that is, if you can /find/ s15 seats!) if you want aftermarket, custom brackets are required b/c of the 'side' mount on one of the rails, you'll end up w/ your head hittin the celing ifyou dont.
Could be wrong
junk yards if your luck is good, but usualy there either grimy, ripped, or theres only one side, last cause EBAY. I read from nissanperformance.com that the seats from S13- S15 all use the same brackets, so it should be fine, not sure about the back seat, anyone know if a S14 backseat would fit into a Coupe S13?
NISMOdrifts13
Jan 12, 2005 11:15 PM
