ka-t progress
hell yea man get it done. man the first time i hit boost i smiled so hard man. i knew it would feel great because my car pulled hard while it was still NA do to the massive weight reductions and small meaningful mods.
i found a new place that tunes/chips ecus for alot less than an emanage piggyback or jwt and enthalpy tune... so i will be going a different route now. until then it will just sit.
ps: nominate me for ride of the month to help motivate me to finish up
It's alive!!!!!
idle video will be up shortly
runs but not that great. e-manage is not the way to go... too few people run them on ka's so its a little tricky to get timing/wiring/fuel maps and info. full ecu tune in the near future
edit:
http://s7.photobucket.com/albums/y28...t=c6cf9dd2.flv
please disregard the ghetto bov recirc and pcv
edit:
what type of spark plug wires are you running? Is it the NGK NX13's? And also what type of spark plugs are your running?
P.S. did you have to remove the big black crash bumper under the stock front bumper to make the intercooler work?
yeah metal bumper fully removed unfortunately. i might get one fabbed up this coming summer.
i am running ngk bk6er plugs i think (1 step colder than stock). im not sure which plug wires but i know they are ngk also
new cosmetic goodies:
http://img512.imageshack.us/img512/9...ssrear1ro6.jpg
wheels x4. 16x8+18 and 16x9 0. will run 5mm up front for a little more flushness. they will be pained gold or bronze metal flake with polished lips
also 5lug skyline gts rear hubs, s14 rotors, and s14 front hubs spindles knuckles
thanks guys. i wont be able to mount them for a few weeks probably
living 3hrs away from your car kinda puts a damper on things. i still need to resolve the timing issue. also my power steering problem (not sure if i mentioned it) is probably a bubble in the line... I probably pumped some air in the system when the belt was changed. I will bump the thread when i have an update again.
