ka-t progress
Old Aug 9, 2006 | 02:14 PM
ka-t progress... update 4/6: all 4 starions on!
still to do, install injectors, plugs, secure hotpipe, recirc bov, install ngk afx wideband, install e-manage & make some maps, boost gauge, run misc vac lines
i figure i'm about halfway there and i start school on the 23rd
Old Aug 9, 2006 | 03:30 PM
Looks good, keep us updated.
Old Aug 9, 2006 | 04:17 PM
good ****!
looking good, so what kinda equipment is that? ssac?
well keep us updated.
Old Aug 9, 2006 | 04:26 PM
basic equipment:
ssac mani
sr t25
ebay 3" downpipe to 3" testpipe
xs power fmic kit
jgs tools oil supply/return kit
blitz dd bov
apexi n1 duals
still to go in:
sr 370ccs
walboro 255 (looking for a new one)
greddy e-manage
ngx afx wideband
misc vac/boost lines and gauges
Old Aug 9, 2006 | 06:34 PM
very nice man, def keep the update!
Old Aug 12, 2006 | 10:43 AM
mechanicmannic's Avatar
yeah nice set-up
Old Aug 12, 2006 | 03:38 PM
so i started it today and forgot to put an oil filter back on the motor should be fine it died real quick and i only lost about 1/3 of a quart of oil. should be up and running fairly shortly
Old Aug 13, 2006 | 12:09 PM
All Mighty KA-T's Avatar
LOL.....i did that myself
What E-Bay FMIC did you buy.....i'm looking into buying a FMIC kit in a week or so. If you could give me a ( link ) to the one you bought or one like you bought, that would really help me out......and your cars looking good by the way.
Old Aug 13, 2006 | 06:45 PM
http://cgi.ebay.com/ebaymotors/FMIC-...QQcmdZViewItem
the ic core is really overkill for a t25 though. if i could do it again i would get one 1/2 as tall and keep my metal bumper
Old Aug 14, 2006 | 12:06 AM
*Tx_BLooD_240*'s Avatar
how many miles does your motor have?
Old Aug 14, 2006 | 04:47 AM
Thanks for the link. Did you need to modify any of the piping to make it work? thanks
Old Aug 14, 2006 | 08:45 AM
my motor has 97k
the ic piping works without mods, but you will need something on the throttle body to make it reach the coldpipe. (you can see i have a 45 degree bend and 2 black couplers). i have heard s13 sr fmics probably fit with less headache.
Old Aug 14, 2006 | 12:05 PM
I have heard the same thing about the S13 ColdPipe, and thanks for the info on the FMIC......i'm going to buy that same kit next week + i'm going to but the 45 degree bend. One more ( ? ) that 45 degree bend.....is it 3 inch or 2.5 inch piping, b/c the piping in the FMIC kit is 2.5 inch piping and the throttle body is 3 inch in (D) so i just wanted to know if i have to buy a 3 inch 45 degree piping or a 2.5.........thanks for all the help.......
P.S. Did you have to cut a hold in the batt. holder for the FMIC piping?
Old Aug 14, 2006 | 01:47 PM
the tb inlet is more like 2.75 as is the cold pipe. a 2.5" 45 degree bend with 2.5" couplers on either side will work best (you will have to stretch them a tad to fit over the tb and coldpipe. i used a 3" 45 degree bend with 2x 2.5/3" reducers. be prepared to cut the 45 bend pretty short. a silicone bend might be your best bet
anyhow the e-manage main harness is now wired up. i havent decided if i should use the ignition harness if i dont want to mess with timing too much. anyone have a driver so my comp will talk through the usb to the blue unit?
Old Aug 17, 2006 | 08:58 PM
everything is in. i found some base timing/fuel maps that im going to give a try tomorrow morning i'll be sure to make a video if all goes well
