picked up an s14,its definitely a little different, needs some stuff, check it out
Old Dec 9, 2009 | 12:32 PM
  #181
alex_s817's Avatar
thanks man, i cant wait to make a video haha
Old Dec 9, 2009 | 02:41 PM
  #182
carps13guy's Avatar
+1 for vid, its gonna sound epic i bet. and you'll have one clean looking bay when your done & the wires are loomed and hidden
Old Dec 9, 2009 | 11:15 PM
  #183
The startup video from the previous owner sure is EPIC LOL.
Old Dec 10, 2009 | 02:50 PM
  #184
alex_s817's Avatar
thanks to my friend Spencer for the hook-up on some heat wrap, i got the manifold wrapped.
tightened the fitting and put the feed line on
set-up the vacuum manifold, i wish is didnt say fastturbo on it lol
re-did the rear coolant hose coming off the head, used a metal hardline instead of a plastic heater fitting
new vac line from booster and t to vac manifold
oil feed line connected
new vac lines for the reg and gay ricer bov
finished the oil return, electrical tape is a great way to avoid scratches if you dont have an wrenches
charge pipes hooked up
couplers look like **** but they are all i have for now, black ones and new ic pipes soon enough
heat sleeve for the return line, dont want that manifold burning through it
bay as of now, going to try starting the car tomorrow
coming together, hopefully it runs
Old Dec 10, 2009 | 03:57 PM
  #185
Awesome man. What's the deal with the fuel pump?
Old Dec 11, 2009 | 09:05 PM
  #186
alex_s817's Avatar
shoot man im not even sure. i was going to just run it off of a 12 volt constant and the battery with a relay, but i tried turning the car over today and got nothing. im not sure why, but im guessing the factory fuel pump trigger and this are related, so i might as well try to figure it all out. looks like the harness will be yanked once more, and ill try to go through each wire individually until i get it. a plug and play harness is $450 which is the only thing holding me back
Old Dec 14, 2009 | 08:56 AM
  #187
nissandrift's Avatar
So were you able to work on it this weekend, or do you have a few finals left? After your done with that harness you can come work on the harness of the project Im working on... all the wires were stiff/cracked due to age.
Old Dec 14, 2009 | 09:22 AM
  #188
alex_s817's Avatar
alright well after much research on the problem, and deciding it had to be something dumb since i was 99% sure i hooked up everything the same way it came off, i got the car to crank. ha its not much, but the fuel pump wiring isnt quite done so until then thats all i got. it ended up being one plug(the gray 3 wire which is used to ground the starter!!!), it simply wasnt plugged in. when i relocated the dash wiring i guess i just forgot to plug the two together, but i had zip tied them both under the air bag try since i wasnt sure what to do with them. doh so dumb! i was focusing too much on the engine harness being the potential problem and just over looked it.
with that being said, the fuel pump relay is mounted and completed wired with the exception of the trigger wire being ran. i called local junk yards today trying to find an s14 ps reservoir (i really dont want to drill any holes for the s13 one) but i had no luck. im going to try making an adapter so no new holes will be necessary.
on top of that, i wasted $25 when i was connecting the coolant lines to the turbo. the lower feed leaked everywhere when i took the plug off and i didnt have the oil return line hooked up. pretty sure coolant went down in the oil pan, so i had to buy 4 more quarts of oil and drain the brand new stuff i just put in. better safe than sorry i guess.
Old Dec 14, 2009 | 10:00 AM
  #189
alex_s817's Avatar
down pipe ready to go, still need a 3 inch flex section welded in
fuel pump hard wire routing
grounded everything, sounds really good
got the car out in the light for a little bit while i cleaned the garage
Old Dec 14, 2009 | 01:07 PM
  #190
Nickmerrone's Avatar
simply beautiful.
Old Dec 14, 2009 | 08:17 PM
  #191
alex_s817's Avatar
thanks nick
mounted the boost controller and ps reservoir today . ps resi only mounted with one bolt at the moment since i dont want to drill a hole unless i have to.
Old Dec 14, 2009 | 09:38 PM
  #192
1SXY240's Avatar
I am so jealous of your car haha
Old Dec 15, 2009 | 11:30 AM
  #193
Zenki_SliderS14's Avatar
I love it! Feels like you made a baby in the beginning of the thread and trained it to be a warrior. hahaha. Im so asian -_-
Old Dec 21, 2009 | 06:19 PM
  #194
alex_s817's Avatar
haha thanks guys, i hope to have it running this week. some stupid little wiring issues are holding me back but i think ill be able to figure them out
Old Dec 22, 2009 | 03:09 PM
  #195
Good Job man. Good luck with the issues and PLEASE MAKE A VIDEO Hahaa.
