Removing Carpet
Old Sep 7, 2005 | 07:45 PM
Preston's Avatar
Removing Carpet
What's the best way to remove the carpet without cutting it and without removing the whole dash? Is there a way? I'm trying not to cut or damage any factory parts during my stripdown. Thanks.
Old Sep 8, 2005 | 04:02 AM
h22lude's Avatar
Good luck with that. Those damn plastic clips always break.
There is no way to remove it without cutting part of it.
Old Sep 8, 2005 | 06:04 PM
the cut is hidden anyways if you're worried about that. But yeah - the "best" way is to remove the dash and the impact brace. There's no other choice.
Old Sep 8, 2005 | 07:56 PM
Preston's Avatar
It's out, I cut it, and glad I took it out. I got two small rust holes at the back end corners of the floor pan...gotta fix em up.
Old Sep 8, 2005 | 08:10 PM
h22lude's Avatar
Removing the brace is more then just unscrewing it. You will have to move a bunch of other crap out of the way too.
I am going to cut mine behind the console so it will never be seen
Old Sep 10, 2005 | 01:52 PM
i cut the **** out of mine...but i wasnt ever gonna use it again
Old Sep 16, 2005 | 07:10 PM
well for S14's there's 2 nuts on the left, 2 bolts on the right, 2 bolts in the center, 1 bolt behind the cluster, and you unclip the antenna and airbag harness wires... which to me isn't that much of "a bunch"
drift3i
May 25, 2004 04:24 PM
Mewt240
Feb 8, 2004 08:49 AM
kramsuey2268
Dec 13, 2003 11:11 AM
Rynxprs
Oct 12, 2002 12:42 PM
sinewave
Aug 7, 2002 05:36 AM
