s14 aftermarket steeringwheel
Anyone know if all 89 to 98 share the same aftermarket steeringwheel hub or s14s different from older ones. Gonna buy one and just want to make sure cause ebay and shops post them as all the same. Anyone thats experienced this situation please help out here.
First off, this has nothing to do with a vehicle being N/A so why would you post it here? Moved to Style.
Secondly, I believe you will need one specifically for the s14 due to it having airbags. The s13 one might bolt on no problem, but hubs made for s14's usually have something to bypass the airbags which keeps the airbag light off
Originally posted by steve 14
the air bag is in the wheel not the hub
you can buy aftermarket wheels with airbags
the ecu dosen't give a fu@k if there is an airbag or not
Re: s14 aftermarket steeringwheel
As for the airbag, Some S14 hubs come with a circuit that you plug into the airbag harness when you remove your factory steering wheel. The circuit allows the passenger side airbag to remain fully functional. I know Nismo's hub has this; never saw the HKB example s13 240 linked above until now though.
trust me you don't need a bypass i had one on my s14 which is now on my s13
buy a hub IT DOSE NOT MATTER WHITCH ONE YOU BUY
And learn how to spell "does".
Thanks s13 240 and 12aine for the deeper info on hubs, that circuit is good thing to have if it gets rid of the annoying flashing red light. I'll be looking around for that option along with the hub unless it's too expensive, maybe if like under fourty five dollars all together or like under twelve bucks for the circuit itself. I'm talking boss hub or something cheaper, not the momo stuff cause I'm broke as hell now. I had a momo on my 99 turbo si a couple of years ago for eighty five bucks.
Forgot to add that my airbag light and check engine has been on since I bought the car like ten months ago anyways so I'm use to the lights being on but it be good to have the passenger air bag workin so incase someone rides with you and somethin happens.
Mmo hub is only like $55-60. The circuit adds $ (The Nismo hub IIRC was like $100ish) but if that airbag light is annoying just pull the airbag ECU, since it won't be functional after switching steering wheels
