s14 aftermarket steeringwheel
Old Dec 9, 2005 | 01:31 AM
it's right in the center of the rear seat bottom. the harness runs along the tunnel forward to the center console.
Old Dec 10, 2005 | 03:22 AM
bruinlax22's Avatar
ok thanks, you did this on your car(removed the airbag's and components?) ? what wheels are you guys running and with what hubs/quick releases etc and how do you like them? thanks again 12aine
Old Dec 10, 2005 | 04:49 AM
Yes when I swapped steering wheels I removed the following:
OEM steering wheel
OEM drivers airbag
OEM passenger airbag
OEM airbag ECU unit
OEM spiral cable assembly (under the driver-side airbag)
Airbag ECU to dash harness
There's one more part - the steering column to dash harness. I didn't remove this - but I rewired it so that I can use the aftermarket horn as well as keep my cruise control.
For steering I have the fakie Bride wheel (it's actually lasting long, feels pretty good too if you ask me). I went with a Momo hub over a generic one, and I forgot the name of the quick release; it's pull-to-release type, but unlike the NRG units (2.5" thick!!!!) This one is only about 1/2" thick so the position of the steering wheel isn't that different from OEM.
RandyJordan
Mar 30, 2005 03:09 PM
l2aine
Jan 13, 2005 11:29 AM
madballa
Nov 13, 2004 01:27 PM
Ncal
Sep 30, 2004 12:44 AM
graphikg04
Apr 26, 2003 06:11 PM
