s15 conversion
Old Nov 17, 2004 | 02:59 PM
nisilvia's Avatar
s15 conversion
if i do the s15 conversion then i can put any bumper made for the s15 on my car? is that true or should i just buy the conversion from extreme dimensions and not mix and match my parts?
Old Nov 17, 2004 | 06:08 PM
please search, probably the only parts that would be good from extreme dimensions is the hood and the headlights, check out jspec.com for how to do the conversion right, remember you get what you pay for
Old Nov 20, 2004 | 02:45 PM
Re: s15 conversion
Yes, but it depends on the quality of the parts. If you use an OEM s15 Nissan factory bumper, you'll need the bumper support too. Other than that, you can use any s15 aftermarket bumper.
Don't be surprised if the Extreme Dimensions conversion kt doesn't fit correctly on the first try. or second. or third...
Old Nov 20, 2004 | 05:54 PM
nisilvia's Avatar
u mean the radiator support right? so do you think that raceonusa s better?
Old Nov 20, 2004 | 06:23 PM
no - bumper support. the radiator support is needed for s15 headlight clearance (or you can cut the s14 stocker) but it has nothing to do with the s15 bumper.
the bumper support is the long metal housing where your stock front bumper sits onto.
RaceonUSA is basically Imprtfan/GTP stuff. Some say it's ok, a lot say it sucks too, but I wouldn't know form personal experience. MASA and ICS are good for the body panels, and of course brand names like URAS, FK, etc.
Old Nov 20, 2004 | 07:14 PM
nisilvia's Avatar
do you know anywhere i can get that
Old Nov 20, 2004 | 08:20 PM
its called GOOOOOOOOOOOOOOOGLE "s13.5 bumper" SEARCH
Old Nov 21, 2004 | 12:28 AM
freebie: jspec.com
matt11145
Jul 10, 2010 08:10 AM
menmy240sx
Aug 18, 2005 04:04 PM
s14.5boy
Sep 26, 2004 08:01 PM
FCSilvia
Oct 29, 2002 08:37 AM
Silviaboi
Jul 18, 2002 03:53 PM
